TheButcher
- Joined
- Jun 12, 2013
- Messages
- 294
I am not the most sharpest tool on the shelf, but why not DSD+ just create any missing files if found on startup ? Duh...
Thanks DSD+ team...
Thanks DSD+ team...
Add those known sites to the .P25 data file..."a) You never should've put any P25 trunking entries in your frequencies file; they were never required and they can cause problems"
Roger, got you. Thanks! I did read about it. But I know of site frequencies of some far, far away sites. It is handy to know them and populate them. But I guess if one was in range, the "DSDPlus.P25data" file populates this f info. Fair enough (I hate change!).
The file came with DSD+ 1.101; only way to have a problem is if you nuke the file."b) You shouldn't have removed your frequencies file from the DSD+ folder "
Well I moved it to a backup directory and .rar'ed it and renamed it "Don't Delete!!!" etc (to remind me not to delete it. ...Frequencies backed up). Serves as a reference for me... I then noticed DSD+ bitshing (cant believe this word has been filtered, stupid Males!, lol. I was referring to a Female dog for goodness sake. Oh, modern PC times... I would rather be called a dog than human!). So easily enough, I copied a blank (zero byte file) there and named it "DSDPlus.frequencies" etc. Problem solved. Just would be nice if DSD+ created it in the first place...
Exactly."c) If you use multiple dongles and don't really care how they get picked/used, specify -i0 (or no -i at all) in your FMP24 command lines "
Well I do and I have not played with this yet. sounds like ability to specify dongle via serial number (must all be unique, I guess too...) is gold. This is / was a good addition (thanks team). If for example, one had, say, 2 dongles (for simplicity), each had different aerials (beam and vertical for simplicity), one has the tools to specify WHICH one is used. Brilliant.
Close. I see you've got it sorted out now."d) If you use multiple dongles and do care how they get picked/used, program each one with a unique serial string and use those strings in your FMP24 command lines "
Not got this far, yet... (Time for play!).
Sooo, instead of doing...
"START FMP24 -i1 (etc, etc)"
Do...
"START FMP24 -ixxxxxxxx"
Where "xxxxxxxx" is the unique serial number of the dongle?
Will give that a try!
No prob.Thanks for your step by step help.
Yep, looks right to me. I've done it on a local network.ps. Got to play with the IP feature too. I would like to have a dongle in say, a different City... (For reference... "DSDPlus -i192.168.1.123:20000")
