lwvmobile
DSD-FME
SDRpp has been giving me issues on mint so I have not been able to test out the DMR trunking yet
Not quite sure what kind of problems you've had with SDR++. If its an issue with linking up or using rigctl, just make sure that both are started up and listening, and with audio, that its set to TCP output and not UDP output. The appropriate settings are in the image below.
Alternatively, if you do want to use GQRX, I wouldn't advise using the UDP audio connection, I made some attempts to make it work with DSD-FME, but I couldn't ever get frame sync out of it, despite being able to read the UDP samples just fine, so had some issues with that, but to be honest, you can just as easily use the virtual sink and have DSD-FME listen to that and then use the same RIGCTL method to control it, just make sure to hit the PC Network looking icon towards the top to turn on the 'Remote Control' for GWRX (rigctl) and then specify the port it wants, which I think is 7356 if memory serves. Here is a video or two of me demonstrating its use on GQRX, I made these along with the other ones I posted, I just forgot I post them.
Has anyone else had issues with the curses menu not responding? I just did a new mint install and I am woundering if this is issue with my setup or a known bug . Right now the menu will pop up about 60% of the time.
Yeah, it does that sometimes if there is no audio to listen to, not sure why, but the easy workaround for this is to open the 'pulse audio volume control' software, and just leave it open in the background. It usually happens to me in a Mint VM as well. I have no idea why opening volume control fixes it, but it does, thinking its something to do with the pulse server.
EDIT: I DO know why the menu is sluggish, I forgot, its because I close the pulse audio input and output instances when opening the menu to prevent a buffer overflow, so opening the pulse audio volume control is a quick work around to prevent the menu from being sluggish. It always responds, but it can take it a few seconds sometimes, and just leaving that open in the background keeps an application open on it and makes it disconnect and reconnect to pulse much faster, and I don't know why THAT behavior exists with pulse, but it does.
