DSD+ Status
D
DaveNF2G
Guest
Just wanted to report that I am having excellent results with DSDPlus v1.51 now. I have my SDRSharp settings tuned correctly and have switched from VAC to VB Cable to carry signals between apps. I have found that VB Cable seems to work better with less fiddling.
Yesterday, I was scanning a three-repeater Capacity Plus system using SDRSharp, the Frequency Scanner plugin (the one from the Russian site), DSDPlus and VB Cable. I even posted a couple of videos to Twitter/Instagram/Facebook.
Having Slot 1 come out the left stereo channel and Slot 2 out the right is an unexpected bonus.
I am hoping that the DSDPlus author is considering the addition of GID and RID tables for TRBO systems and variants to the program's capabilities.
slicerwizard
Toronto, Ontario
slicerwizard,
My question regarding the program hanging was not in reference to DSD+ proper. I know the proper syntax for the DSD+ command line and I am familiar with the -h switch and have used it. My original question in this thread involved how to determine the correct value for each advanced decoder option. User n4yek was kind enough to direct me to dsdtune.
The dsdtune program was hanging when I tried to run it
If you are familiar with DSD+ 1.05x's command line syntax, then you should have been aware that DSDtune is using incompatible syntax. Instead, you asked how long it would take to run?
You apparently are not familiar with dsdtune and mistakenly thought DSD+ was hanging.
As a matter of fact, when run with DSDtune's current syntax, DSD+ 1.05x will "hang" as it waits for an Esc key press that will never come.
I am patiently waiting for deboe to find time to address the issues in the dsdtune program.
Next time read and understand the flow of subject matter in the thread before offering advice. Thanks for the off-base RTFM advice.
Or you could just do the tuning yourself, since you've done your reading and understanding...
mancow
N.E. Kansas
How do I configure this new version? When I double click the program it instantly starts running. It doesn't wait for any configuration input information.
joeuser
The Wretched
North Central Kansas
Well, I can only report great success with this latest version. Towards the end of the week the Event Log will go blank but a simple restart fixes it. Otherwise it runs 24/7 until I reboot the system, once a week. Still would like to see resizable windows for the Event Log & Source Audio windows but its nothing but a request. Appreciate all the hard work on this program & making it freely available to our community!
rivardj
Michigan
deboe,
Thank you so much!
DSDTune even runs great on my little Acer Netbook.
Saint
Fort Erie Ontario Canada
rivardj
Michigan
It helps optimize the audio from the data-stream for your listening pleasure.
Use the following program with a 'Raw' audio capture from DSD+, 30-60 seconds worth, and it will provide the optimal numbers to use for the options.
https://github.com/dreinhold/dsdtune/releases/tag/v0.0.4
You can do this manually, but the DSD Tune program can do it much quicker.
Once you have your numbers for the options, you would want to make start-up batch files for type of audio you are decoding (ex P25.bat, TRBO.bat, Provoice.bat, etc...) This would then give you good sounding audio.
The post from the author of DSD Tune: http://forums.radioreference.com/2095681-post131.html
The above quoted post from n4yek got me up and running. DSDTune takes a while to run, the amount of time depends on your computer specifications.
ak4fn
Fredonia, KY
dsdtune
I get "Could not get decode string" do I need to do something different?
Code:
d:\Users\Scan\Desktop\DSDPlus-1.50>dsdtune.exe -i DSDPlus-Raw-Input_2014-11-10@120526.wav -f1
Checking option -dr
Running dsdplus.exe -o0 -O NUL -f1 -drXXX ? DSDPlus-Raw-Input_2014-11-10@120526.wav
best value of 0 with -dr0
Checking option -dh
Running dsdplus.exe -o0 -O NUL -f1 -dr0 -dhXXX ? DSDPlus-Raw-Input_2014-11-10@120526.wav
best value of 0 with -dh0
Checking option -ds
Running dsdplus.exe -o0 -O NUL -f1 -dr0 -dh0 -dsXXX ? DSDPlus-Raw-Input_2014-11-10@120526.wav
best value of 0 with -ds0
Checking option -dd
Running dsdplus.exe -o0 -O NUL -f1 -dr0 -dh0 -ds0 -ddXXX ? DSDPlus-Raw-Input_2014-11-10@120526.wav
Using a different DSDPlus-Raw-wav file:
Code:
d:\Users\Scan\Desktop\DSDPlus-1.50>dsdtune.exe -i DSDPlus-Raw-Input_2014-11-10@123321.wav -f1
Checking option -dr
Running dsdplus.exe -o0 -O NUL -f1 -drXXX ? DSDPlus-Raw-Input_2014-11-10@123321.wav
Checking option -dh
Running dsdplus.exe -o0 -O NUL -f1 -dr0 -dhXXX ? DSDPlus-Raw-Input_2014-11-10@123321.wav
Checking option -ds
Running dsdplus.exe -o0 -O NUL -f1 -dr0 -dh0 -dsXXX ? DSDPlus-Raw-Input_2014-11-10@123321.wav
Checking option -dd
Running dsdplus.exe -o0 -O NUL -f1 -dr0 -dh0 -ds0 -ddXXX ? DSDPlus-Raw-Input_2014-11-10@123321.wav
deboe
0x045C
That is weird, looking at it I dont think DSDPlus is getting a good decode from that file that all.
Can you run this and post the results.
Code:
dsdplus.exe -o0 -O NUL -f1 ? DSDPlus-Raw-Input_2014-11-10@123321.wav
ak4fn
Fredonia, KY
I might be wrong, but I think it only works with 1.051.
You are right and I was using 1.05. Thanks! Here are the results:
Code:
Checking option -dr
best value of 139927 with -dr1
Checking option -dh
Running dsdplus.exe -o0 -O NUL -f1 -dr1 -dhXXX ? DSDPlus-Raw-Input_2014-11-10@120526.wav
best value of 139927 with -dh2
Checking option -ds
Running dsdplus.exe -o0 -O NUL -f1 -dr1 -dh2 -dsXXX ? DSDPlus-Raw-Input_2014-11-10@120526.wav
best value of 139927 with -ds56
Checking option -dd
Running dsdplus.exe -o0 -O NUL -f1 -dr1 -dh2 -ds56 -ddXXX ? DSDPlus-Raw-Input_2014-11-10@120526.wav
best value of 139927 with -dd6
Checking option -dv
Running dsdplus.exe -o0 -O NUL -f1 -dr1 -dh2 -ds56 -dd6 -dvXXX ? DSDPlus-Raw-Input_2014-11-10@120526.wav
best value of 139927 with -dv20
+------ RESULTS -----+
Switches you want to use :
   -dr1 -dh2 -ds56 -dd6 -dv20
deboe
0x045C
Ohh yeah sorry..
I am going to try and add the check for dsdplus version tonight or tomorrow.
ak4fn
Fredonia, KY
Thanks!
Ohh yeah sorry..
No worries, my mistake! I had downloaded and unzipped the 1.51 version and forgot that I never replaced the old executable! So my fault! Thanks for the program! it sure beats me doing it by hand using paper and pen to figure out the best settings!
garys
Central Texas
Thank you!
Open your command prompt window and type or copy/paste the following:
DSDPlus -h > Help.txt
This will save the the screen output as a text file called "Help.txt".
You can use another file name if you don't like Help.txt.
