I don't know what to suggest, but if you do get it running, I'd like to know if you have the same issues that I reported for the VC Console & Log output. As posted here..When 2.444 went live I tested it on 1R and was working fine. Today I wanted to do some tests with two dongle trunk tracking and it seems that VC side does not respond when there is channel activity on the CC side. Probably is something on my side with the settings but didn't manage to find it, so it would be great if someone point me in the right direction. Here is my setup:
- two rtl-sdr devices - confirmed working and ppm set correctly
- here is my bat file:
start DSDPlus -rv -i20006 -O NUL -fn -E -v4 -_3
start FMP24 -i2 -rv -o20006 -a1 -e0 -b4 -g28 -z0 -P41.7 -_1
timeout /t 1
start FMP24 -i1 -o20005 -a1 -e0 -b4 -g19.7 -z0 -P45 -_1
start DSDPlus -rc -i20005 -O NUL -fn -E -v4 -_3
Some screenshots of what I am seeing:
View attachment 151844 View attachment 151845 View attachment 151846 View attachment 151847
What I have tried so far:
- reordering startup sequence
- deleting dsdplus.bin file
- setting receiver roles manually from the menu
- playing with antennas and gain
- trying different sites from the same network
- trying different networks
So far nothing helped. I got good clean signal on both CC and VC channels. Gain is set as lowest as possible where clean signal is at it's maximum (on VC side it could be even lower but for various reasons there is no need for that). So please if someone saw something simple (or not that simple) that I am missing, please, show it to me
Here is a short IQ and WAV recordings from CC during minor activity: Ufile.io - 1700830228
DSDPlus - DSDPlus 2.443 available
OK, My 2¢ on these recent updates. Running CC/VC instances with 2 V3 dongles. The "Added display of Algorithm ID and KID for encrypted P25 TDMA calls to event log and Current/Seen Groups window." as described in 2.395 is broke and has been since after 2.368. It simply ain't displayed in either...
I tried this new rev and had the same results as posted for 2.443. Apparently you and me are the only ones using CC/VC copies, everybody seems to use 1R.
You're possibly missing a new basefile that needs replaced in addition to the DSD.EXE
