DSDPlus FastLane
raruzicka
Cedar Rapids, IA
I renewed my subscription to DSDPlus and received the latest version. I noticed the VAC is greyed out and uses TCP. I have an older version that i am forced to use because of this. Does DSDplus no longer use VAC? I also use SDRSharp to send the audio to DSDPlus. Can anyone tell me where I am going astray?
a417
FMP24 is the preferred way to feed DSD+. SDR# is not the optimal way, and provides less features.
slicerwizard
Toronto, Ontario
You're not reading the docs.
Using DSD+ with external signal sources
DSD+ can be used with external signal sources such as a properly discriminator-tapped receiver
or SDR software such as SDR#. To use DSD+ with these sources, use the menus in DSD+ to
select Passive Digital Monitor mode and then to select the audio input device that carries
the digital audio signal. When running in this mode, DSD+ can be used to monitor conventional
analog and supported digital signals; DSD+ will not directly support trunk tracking.
raruzicka
Cedar Rapids, IA
thank you. i missed that.
