East Kentucky Power Cooperative (EKPC) - DMR VHF
scannerboy02
If it's helpful I just updated my map with the spectrum blocks as shaded areas that can overlay the other licenses making it a bit easier to see what covers what.
scannerboy02
These are the centers for the frequency blocks. They also have some 220 MHz blocks but I'm not sure what they are using them for so I didn't include them in my map, for now.
157.2
157.2125
157.225
157.2375
157.25
157.2625
157.275
157.2875
157.3
157.3125
157.325
157.3375
157.35
157.3625
157.375
157.3875
157.4
157.4125
157.425
161.8
161.8125
161.825
161.8375
161.85
161.8625
161.875
161.8875
161.9
161.9125
161.925
161.9375
161.95
161.9625
161.975
161.9875
162
162.0125
162.025
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I'm attempting to search these licenses and im not getting them in the DB.
Use the FCC Search directly at the FCC
FRN: 0001792803
Radio Service: PC (Public Coast Stations, Auctioned)
These types of licenses will not show in the RRDB. You must search the FCC directly
And these usually will not show specific frequencies but frequency ranges, and they typically will be licensed for an extended area.
Example of two that cover 161.8125:
When you click on each of those licenses, note the Market / Submarket and ranges licensed. Then clcik on the map to get an idea where they might be in use.
Mike
scannerboy02
And each block is 0.0125 MHz wide (in this frequency band) so doing a little math allows you to find the center of each block and it has been my experience (100% of the time so far) that they use the frequency in the center of each block.
Remington12G
GØT AES?
161.8250 possibly Shelbyville Substation. Strong signal upon approach on I-64. Updates to follow with Metro Louisville as well.
Remington12G
GØT AES?
153.2150
Region: 3
Site ID: 1
Burgin (Mercer County)
Online and broadcasting, submitted for an update. Also, Renaker (Harrison County) is broadcasting SCADA currently. I will be driving down to the southern part of the state tomorrow to check for more sites that are online.
Remington12G
GØT AES?
Also, My Uniden is reading out Network ID: 9 but DSD is spitting out 10. I did note at one point DSD tried to switch to Network ID: 9 but refused. Not sure why this is occurring.
mtindor
FMP24 PRO USER
When you are locked on a strong site with DSDPlus, grab a screenshot and attach it (attach it, so it can be expanded without blowing up the page size, which might happen if you embed it).
I am interested in what it reports for the type of system (down at the bottom left of the Event Log window). It might take a minute parked on a good control channel for it to show.
mike
Remington12G
GØT AES?
Currently In Corbin. Strong signal 161.8125 R: 8 S: 5 not exactly sure which tower this is in Laurel County. Originally picked it up in Caryville, TN on 75. Will post continue to post updates
Remington12G
GØT AES?
153.275
Region: 1
Site: 1
CC: 0
Couldn't tell what site or county this is coming from since both licenses are very close in proximity, any help with this site is much appreciated.
empireco
Central Ky
I'd like to be able to upload pics here period.
Everytime I try to do so it says my files are too large for the server, doesn't matter if they are pics from my iPhone or pics from my Nickon D-3100 DSLR.
So what's the secret?
mtindor
FMP24 PRO USER
That makes sense. Anything from a camera will likely be in RAW format. You need to save-as or convert-to a JPG, GIF or PNG. Then upload that. A RAW photo will likely end up being a couple MB in size, too big for inclusion in the forum.
Mike
mtindor
FMP24 PRO USER
Mike
I'm sure there are easier ways to do this (such as simply saving the images in a different format), but you could open a large image in MS Paint or whatever your paint program is in your OS, and then just resave it as a PNG, GIF or JPG. If you do that, try to pick a method that preserves good resolution. You only need to have a 1280x-1024 or 1024x768 image of good quality, and a RAW image will a few million x few million in size, which is why RAW is so much larger.
