Favorites
CJZOMBAR
I set up a favorite list of my local Police Departments. Works great. Added my State Police and it's in Sentinel it's in the scanner but it does not scan that department. I have made sure Monitor and write are on. I've assigned keys. I have made sure the services are checked and it still won't work. SSSSSSOOOOOO frustrated I want to throw my new scanner. PLEASE PLEASE help.
hiegtx
Mentor
Dallas, TX
Are the State Police using a trunked system? And, if so, did you add the sites for the area?Are they on the same system as your local PD?
What is your location? City (or county) and state are sufficient.
nessnet
Eastside of Lake WA
Did you append the SP system's sites in there as well?
Maybe just set up a seperate favorite for the SP...
CJZOMBAR
yes to trunked. i believe i added the sites how do i check? I don't believe they are the same system, Chesapeake VA. I have Norfolk, Portsmouth, Chesapeake, Virginia Beach, Hampton, and Newport News and they all work great.
CJZOMBAR
You are going to get a lot further in getting help if you give us more info.
Yes - to what question I asked?
You have been asked the state/county where you want to monitor.
What radio are you trying to program?
Help us to help you.....
Richard, I answered yes to you to the ONLY QUESTION you asked, and that was I'd I Appended. I answered ALL the questions hiegtx asked.
hiegtx
Mentor
Dallas, TX
Chesapeake shows to be on this system:
Portsmouth is on a different one:
Norfolk shows yet another different system:
Virginia Beach on yet another different system:
I do see some Portsmouth talkgroups on this ine as well,
Your state police should be on the statewide system, STARTS/
Not being in your state, I can't be sure of who uses how much of each system. I would suggest that you request that your thread be moved to your state (Virginia) forum. That way, someone more local to you would be better able to help you sort out exactly what you do need.
To have your post moved, click on the Report link in the lower left corner of your post. Then, request that a moderator nove the thread to your state forum.
CJZOMBAR
I appreciate all your help. All my cities are good, just cant get the state police to scan.
tglendye
Blue Ridge Mountains, Shenandoah River- VA
Virginia STARS is what you want for VSP. I would create a Favorites List for your local agencies and a separate one for STARS. Chesapeake channels (Division 5) is the area you are in.
What scanner are you using? I'm guessing an SDS100/ 200 or a 436/536. If you are basically stationary with it, select only 1 or 2 of the closest sites for a control channel. If you load too many, it wastes time scanning control channels that are out of range. Another option is to use Location Control in Sentinel and enter your zip code and allow the scanner to select your sites. But if you do this, I would choose a range close to 0 miles (less can be more).
And lastly, if it is a database scanner, I would turn your Database to Off and scan only your Favorites Lists. A lot of the times the database will scan too many frequencies and systems. And it sounds like this is not a problem for you, but it would be worthwhile to check your Service Tags to make sure you have selected the Services you want to receive.
