Ok, so I trying to design a cost-effective solution to have a speaker system through-out our firehouse. The speaker system will have 2 sets of speakers, 6 Alerting Speakers, and 6 Speakers for the Scanner. The 6 Alerting Speakers will Have 1 Volume control in-wall knob. While, the 6 scanner speakers will have 5 separate control knobs in each area. The Purpose for that is, we do not want members turning off the alerting speakers. Attached is a .zip file with a diagram of the system I have made. It may be confusing...
My specific Questions are as follows:
1. Will this work?
2. Will using Mono audio from the BCT15 and Minitor III Charger be good enough quality for the system? The reason I would go mono(left Alerting rightside Scanner) is because the amp only has 1 input channel).
3. Will the amp be powerful enough for this?(This system came as a package so I am assuming it is made for the speaker set.)
4. Any other issues I should be concerned about?
The Speaker system is found at
Amazon.com: Pyle Studio Audio System Package for the Studio, Bar, Concert, Stage, Performance, Home, etc. - PCA4 Mini 2x120 Watt Stereo Power Amplifier - PSS6 6 Channel High Power Stereo Speaker Selector - x6 PDIC51RD 6 Pairs of the 5.25'' Tw
Attached is the .zip with images of the slides of the system.
Thank you, Matt
1. Will this work?
Thank you, Matt
