- Joined
- Nov 1, 2024
- Messages
- 22
- Reaction score
- 7
Listening to the franklin county scanner online today I heard them mention a operations being on tac 1. Does anyone know the frequency for this? Is it just the ops frequency listed in the database?
They have an aditional repeater frequency 155.820 that is a good possibility. It is also licensed for simplex base and mobile. It is low power (5W) so will probably not be heard unless you are in the vicinity of the activity.Listening to the franklin county scanner online today I heard them mention a operations being on tac 1. Does anyone know the frequency for this? Is it just the ops frequency listed in the database?
Since the OP did not specify Fire I assumed the question was about Law so my response does not apply. If 2W MURS frequencies are used they would only be heard in the immediate vicinity of the incident.They have an aditional repeater frequency 155.820 that is a good possibility. It is also licensed for simplex base and mobile. It is low power (5W) so will probably not be heard unless you are in the vicinity of the activity.
Based on the low power and location of this repeater, my money is on this channel being the Franklin County Jail channel. The licensed location is the County Public Safety complex.They have an aditional repeater frequency 155.820 that is a good possibility. It is also licensed for simplex base and mobile. It is low power (5W) so will probably not be heard unless you are in the vicinity of the activity.
I considered the same possibility and that it likely has never been submitted to RRDB due to only able to be received near the Jail.Based on the low power and location of this repeater, my money is on this channel being the Franklin County Jail channel. The licensed location is the County Public Safety complex.
I agree. I’ll try to get over that way later this summer or sometime this fall for a reconnaissance mission.I considered the same possibility and that it likely has never been submitted to RRDB due to only able to be received near the Jail.
