Did you completely uninstall sentinel and all files and registry settings associated with it? You mentioned it was saving to onedrive and mentioned that you also uninstalled onedrive.
yes, my intention was to try after the new Monday download, thanks... I will check those paths again, as i did delete those files .....(using BCDx36HP )
Don’t think wait till Monday will make any difference. It’s been stated that there is nothing wrong with the database or sentinel since nobody else has this issue.
Look in your Windows file system for C:\ProgramData\Uniden\BCDx36HP_Sentinel\Updater\...... In that folder, delete the .GZ file that starts with the name "MasterHpdb" Should be the only .GZ file in that "updater" folder.
Re-start Sentinel and then from the top tool bar, Update --> Update Master Database. Sentinel will download a new copy of the current database
@RMason@fxdscon BINGO! After 24 hours of trying EVERYTHING, THAT worked! Thank you! all fixed.....
Close out Sentinel.
