Sentinel: Frequencies and systems missing from sentinel
richee2000
Monitoring NYC from Sea Bright NJ, East Hanover NJ
The Sentinel database files are located at (depending on what version you are using)
C:\ProgramData\Uniden\BCDx36HP_Sentinel\Database​
C:\ProgramData\Uniden\HomePatrol_Sentinel\Database​
Did you remove the files in this directory when you uninstalled and removed old folders?
This is a separate location from the profiles, favorites list files and discovery log.
You may want to try again tomorrow after the weekly database update occurs.
yes, my intention was to try after the new Monday download, thanks... I will check those paths again, as i did delete those files .....(using BCDx36HP )
dave3825
Suffolk County NY
Don’t think wait till Monday will make any difference. It’s been stated that there is nothing wrong with the database or sentinel since nobody else has this issue.
RMason
Colorado / Mississippi
You can also try the following:
fxdscon said:
Close out Sentinel.
Look in your Windows file system for C:\ProgramData\Uniden\BCDx36HP_Sentinel\Updater\...... In that folder, delete the .GZ file that starts with the name "MasterHpdb" Should be the only .GZ file in that "updater" folder.
Re-start Sentinel and then from the top tool bar, Update --> Update Master Database. Sentinel will download a new copy of the current database
If deleting that file doesn't do it, try this next-
From Sentinel's top tool bar... Tools --> Options --> Reconstruct Full Database... click on the "Start" button.
richee2000
@RMason @fxdscon BINGO! After 24 hours of trying EVERYTHING, THAT worked! Thank you! all fixed.....
Close out Sentinel.
