Futronics UHF Connect Plus
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Concerning Site 16, Wauseon (or Napoleon):
I was asked to verify the neighbors for this site, compared to those listed in the database. They are, indeed, the same as listed in the database: 5, 9, 13, 18, 19, when listening to the control channel on 461.5875.
Thank you, Dave. We appreciate it!
Mike
mtindor
FMP24 PRO USER
Site 12 - Berlin Hgts -- need updated neighbor list
For anybody who may be able to copy Site 12 (Berlin Hgts, Erie County) control channel on 451.9625, when you get time I would ask that you run your SDR software on the 451.9625 control channel and report back the current list of site neighbors.
NOTE TO ALL: remember that there can only be five site neighbors broadcast on a site. So if you see a site broadcasting five neighbors, and it's not broadcasting one of the neighbors you would expect, it is likely because it's limited to 5 and the sysadmin has chosen the 5 neighbors they prefer as the site neighbors or that site.
Thanks guys and gals.
Mike
mtindor
FMP24 PRO USER
System 182 Name Change: Futronics UHF Connect Plus (OH-MI)
Hi Folks,
This sytem's name is being changed in the DB. It was "Futronics UHF Connect Plus (Ohio)". However, it is now being renamed "Futronics UHF Connect Plus (OH-MI).
Futronics UHF Connect Plus (OH-MI) Trunking System, Various, Multi-State - Scanner Frequencies
I'm in the process of attempting to contact ka3jjz and QDP2012 to ask them to update the wiki.
I'm going to ask a moderator to update this thread name as well.
Mike
mtindor
FMP24 PRO USER
Folks,
If anybody happens to be sleuthing a site and needs a one-stop cheat sheet to determine what [licensed] frequencies might be in use for a particular site, I made up a Google spreadsheet of all of the licenses. Some of the licenses are conventional (nontrunked) DMR licenses as well as one or two analog licenses. The reason for this is that it has already been proven that Futronics does periodically use a frequency off of one of their non-trunked and/or analog licenses as part of one or more of the System 182 trunked sites.
And, always keep in mind that not only may a site's control channel be on 454 mhz, but it is also possible that one or more voice channels on a particular site could be in the 454 mhz range either.
If you're using a scanner to scan for activity, you should scan the 422-425 mhz range, 450-455 mhz range, and 461-465 mhz range.
And if you have a scanner such as the Uniden BCD436HP/BCD536HP, you'll want to go into the Menu --> Srch/CloCall Opt --> Broadcast screen --> Set All Band Off [which is the easiest way of doing it] as well as make sure you are scanning in 6.25 khz steps by going into Menu --> Settings --> Band Defaults --> 450.0 and set it to NFM, 6.25kHz.
That way, when you scan 454 mhz you will be able to pick up any active control/voice channels as well as 6.25 kHz spaced channels in search mode.
Futronics UHF licenses and frequencies
Futronics site map
The map includes active sites on the Futronics UHF Connect Plus (OH-MI) system, as well as other Futronics sites.
Mike
OHIOSCAN
Lorain Cnty, OH
Site neighbors
Site Neighbors 451.9625
182-1
182-17
182-26
182-29
182-30
OHIOSCAN
Lorain Cnty, OH
Notes from DSD+
420.0375 NXDN48
420.3000 SITE-158-6 CON+
420.4500 SITE 158-33 CON+
420.7000 DMR VOICE SITE 158.2 CON+
420.8750 DMR SITE 158.3 CON+
421.1125 P25 8D45F.36F
421.1625 P25 8D45F.36F
421.3125 P25 8D45F.36F
421.3625 P25 SITE 8D45F.36F
421.4250 P25 CC SITE 8D45F.36F
421.5125 P25 SITE 8D45F.36F
421.5625 P25 SITE 8D45F.36F
422.2125 DMR CC SITE 182-26 CON+
182-6
182-12
182-21
182-30
422.2375 DMR CC SITE 182-30 CON+
182-6
182-12
182-17
182-26
182-29
422.2625 DMR CC SITE 182-6 CON+
182-7
182-17
182-21
182-26
182-30
422.2875 DMR VOICE SITE 125-8/125.4/ CON+
422.325 DMR SITE-1 CAP+
422.4125 DMR VOICE SITE 125-8 CON+ 19 CH
422.4875
422.7375 DMR VOIVE SITE 125-8 CON+
422.9125 DMR VOICE SITE-1 CAP+
422.9625 NXDN48 SITE R202-36
424.0625 NXDN96 ENC KQA214
424.4375 DMR
424.5125 DMR CC
424.5625 NXDN96 SITE L191-1
424.6625 DMR CC SITE 182-8 CON+
182-3
182-5
182-20
424.6875 DMR CAP+
424.700 DMR VOICE SITE 125-4 CON+
TG#1010
100601
100561
102451
102461
424.7125 DMR VOICE SITE 125-4 CON+
424.8125 DMR VOICE SITE 125-4 CON+
424.8375 DMR VOICE SITE-182-17 CON+
451.3625 NXDN96 SITE-127-1
451.5375 NXDN96 SITE L127-1
451.9375 DMR VOICE SITE 182-1 CON+ (CASTILIA LCN-2)
451.9625 DMR CC SITE-182-12 CON+ (BERLIN HTS, ERIE LCN-1)
452.2625 DMR VOICE SITE-131-1 CON+
452.4875 NXDN96 CC SITE L127-1
452.6875 NXDN96 CC
460.3875 NXDN96 SITE L231-1
461.7000 DMR SITE 182-1 CON+
462.0125 DMR SITE 182.1 CON+ (CASTILIA LCN-3)
462.1125 DMR CC? SITE-182-14 CON+
463.5750 DMR SITE-131-1 CON+
463.6625 DMR CC SITE 182-17 CON+ (GREENWICH, HURON CO)
182-4
182-6
182-7
182-12
182-14
464.8375 DMR VOICE SITE 182-17 CON+
182-4
182-6
182-7
182-12
182-4
463.7750 DMR VOICE SITE 131-1 CON+
463.8750 DMR VOICE SITE
463.9875 DMR VOICE 182-12 CON+
464.0750 NXDN96 SITE L290-1
464.3000 DMR
464.3375 DMR 182-1? CON+
464.8375 DMR
DMR SYSTEM
NET 182 SITE 30 422.2375
CH-1
CH-2
CH-3
CH-4
1000 BASE
10002
10067
10068
10075
10077
10087
10088
10089
10090
11500 BASE
11512
11513
11515
20500 BASE
20517
20518
20532
20541
23000 BASE
23002
23010
23011
23101
23105
23106
23107
23111
23112
23117
23118
23119
23121
23122
23140
23121
NET 182 SITE 26 422.2125 COLOR CODE 1
CH-1
CH-2
CH-3
CH-4
CH-5
CH-6
10000 10002, 10008, 10067, 10075, 10077, 10089,
11500 BASE 11513, 11515
13500 BASE 13506, 13531
MEDIC TRANSPORT
13501 BASE 13503,13510,13511,13513,13516,13352,13520,13522,
13524,13530,13531,13532,13551
21000 21001, 21004, 21018, 21019
21100 21111
463.575
B&C 8 CH'S SITE 131-1 CON+
TG RID USER
3004 LINNDALE PD
3006 80001
3006 80002
3006 80008
3006 80015 TRANSPORTF
3006 80015
3006 80019
3006 80022
3006 80024
3007 40032
3007 40051 KUFNERS
3007 40052 KUFNERS
3007 40056 KUFNERS
3007 40057 KUFNERS
3007 40062 KUFNERS
3007 40063 KUFNERS
3007 40072 KUFNERS
3007 40073 KUFNERS
3011 40057
3013 50000
3013 50006
3014 40232
3014 40234
3014 40235
3016 10007 LOLLY THE TROLLEY
3016 10008 LOLLY THE TROLLEY
3016 10010
6001 40301
6001 40303
6001 40315
6001 40316
6001 40306
mtindor
FMP24 PRO USER
OHIOSCAN,
Thanks for the update. I'm guessing you saw some of the band opening last night. Or maybe your notes are "over time". I gleaned what I could from them. I'm not adding some of the System 182 stuff I saw listed because it doesn't make sense in some cases. Like a couple of the listed DMR voice frequencies for System 182sites, not matching up with FCC licenses anywhere nearby. Since they don't have LCNs listed, I couldn't addthem to the system, but we can add frequencies to the wiki when we are positive they are part of a site but do not know the LCN.
Looks like you were getting some nice signals from across the water.
Mike
OHIOSCAN
Lorain Cnty, OH
YA big opening from Ontario last night, all those logs where past 48 hours. Getting a lot of duel use hits from diff sites making logs bit confused
jdolina
Lorain Ohio
I have not had a chance to make it to site 6 and wont at least for another week. But I did find the following voice channels for sites
451.9875 (site 6) ch3/4 LCN 2 tg 10000 44048
463.2725 (site 30) ch3/4 LCN 2 tg 10000
Also had control channel fro site 17 coming through and was on a different frequency then listed.
463.660 (17) CC NL 4 6 7 12 14
mtindor
FMP24 PRO USER
451.9875 (site 6) ch3/4 LCN 2tg 10000 44048
463.2725 (site 30) ch3/4 LCN 2tg 10000
Thanks john
463.6625 is correct, 463.66 is not. Site 17 listing is correct
If site 17 neighbors need updated in db ill do that this evening
Good work on the additional lcns for sites 6 and 30. Ill update the sb this evening
Mike
mtindor
FMP24 PRO USER
This confirms site 6 as Medina for me, as 451.9875 is listed on a Medina license.
The frequency is 463.275.
I have a feeling you are using an SDR and you do not have it calibrated, as such you are seeing 463.275 as 463.272 and are seeing 463.6625 as 463.66.
I've updated the DB. Thanks for your contributions and hard work!
Mike
jdolina
Lorain Ohio
I am using SDR it is calibrated small step size and some frequencies decode better a little left or right depending on the conditions.
I will take a trip to medina off my list thanks.
mtindor
FMP24 PRO USER
The DMR/NXDN sites I monitor often decode better slightly off center. Not so far off center to be a separate frequency though (not like 6.25 or 3 khz off -- but sometimes 1-2 khz.
Mike
AtlasFBG2
Fremont,Ohio
I got a road trip in today and was able to confirm site 5 and 8 are in Michigan.
Site 182-8 is 424.6625 with neighbors of 3,5,20 Located in Detroit between 75 and the river by Greektown Casino.
Site 182-5 is 461.4875 with neighbors of 3,8,9,16 Located a little way north of Pontiac maybe 100 yards off 75.
mtindor
FMP24 PRO USER
Excellent! Thank you. I've updated the DB. Incidentally, I apologize for not seeing other submissions from you but I forgot that I wouldn't "see" submissions as soon as it turned into a multi-state system until I had one of the superadmins fix something.
Mike
mtindor
FMP24 PRO USER
Observation: I badgered everyone else to sleuth out all of the sites on this system [and you all did]. And the one site left to verify is nearest to me -- I'm the one dropping the ball :)
Site 24 is either Ashland or Nashville. I really will try to do another road trip to figure out which it is.
Thanks to all of you who have contributed. We aren't done now. Now that we know the sites, and we know the licenses [and likely possible frequencies], it's now time to determine how many LCNs are active on each site and then start attempting to determine what frequencies go along with those LCNs.
But I have to reiterate, you all have done a stellar job figuring out the sites!
Mike
mtindor
FMP24 PRO USER
Site 24 is in Nashville. Neighbors of 7,14,17,23
THanks man. You actually made a road trip to Nashville? I was up in Sugarcreek last week -- stones throw away from it. Knew i was going, but I didn't take the scanner because I didn't feel I'd have time to actually drive there.
That's all of the sites now. Time for Futronics to put some more online.
m
