Ok took a trip at lunch to 200 public square to find the cuyahoga site. Of course the antennas are on top of the huntington bldg which should make reception good? In the public square area west of the bldg I can hear the chainsaw and my 436 has trouble locking in on the CON+ control channel although seems to lock in and display the site when TG 0 comes up. Which I really think is TG 10000 but displayed incorrectly another topic. I was able to get a lock and 182-26 under the same circumstances with the antenna off once. I am also able to pick up 182-26 from my office with sdr/dsd+ I am less than a mile from the square and can see the bldg out of my window. I do notice that throughout the day I see NEXEDGE traffic mixed in and do have better decode with just dmr set. That said at times I still get the constant stream of DMR data but the CC and the site ID randomly disappear and come back with what appears no change in signal strength. I have logged and heard TG 10000 as well as 7700 (logged) and 13501(garbled) on the site although traffic is very sparse. I have not been able to receive any other 182 sites in the general location withe either setup.
John,
Forcing DMR will only stop the pesky NXDN notations in the output. It will not stop the CC/site ID from randomly disappearing [when a stronger NXDN signal overpowers it]. The NXDN sig is just walking over / colliding so badly that DSD+ can't pull the DMR signal during that period.
I just wanted you to use -fr to save you from having NXDN trash in your output.
From the location at public square or from your office, does your scanner / DSD+ actually show a super strong signal as it should though? With antenna on scanner or on SDR at your office, the signal should be off the charters [nearly] in SDR# and you should have many bars on your scanner.
I'm guessing you do, but I'd like to know anyway.
Either:
1. You are getting an NXDN sig on the same freq [i would say probably not likely UNLESS -26 is not Cuyahoga and you are pulling it in distantly along with a stronger NxDN sig].
OR
2. You'v egot a strong / stronger NXDN signal on a nearby frequency and the strong signal hitting your scanner / SDR# are just mixing to form DMR+NXDN on the same apparent freq.
Need to be sure you absolutely have a super strong signal. If you don't have a super strong signal on 182-26 from the square or your office, with the antenna attached, you really have to consider the notion that 182-26 may be more distant and not actually public square.
Mike
