G4 program a P25 conventional channel
philacop
Clifton Hgts PA
Hi
I’m using pps ver 4
In zone and channel setting Tab E7 at bottom of page I get a Talk group list setting parameter asking for TGID Grouping list
There is a drop down tab under current setting but when I tab on it it’s blank ??
When I try to save a box pops up saying Please select TGID Grouping list TGID grouping list can be set in previous step Conventional Group ID setting .
I don’t what they want set in Tab E6
Any help really appreciated!
Hi
I’m using pps ver 4
What version of the PPS are you using? V3 or V4?
For others who want to ask the same question...
Add TGs under E6 Conventional Group ID List
Then create a TGID Grouping List using the TGIDs added
Now you can add the Group into the conventional P25 frequency
joncleve
Western NC
How do you edit any of the Grouping lists under tab E6? I cannot or do not have a way to edit them. I am using PPS v0.4.0.38.
joncleve
Western NC
I figured it out finally. I think because I converted my file from an older G4 it doesn't work the same as if I had created it from scratch for the G5.
