G4 scanner.
bobgolf
levittown pa
I am thinking about purchasing a g4 scanner. The person I'm purchasing it through says I need the system code for bucks county to hear the encrypted transmissions. Does anyone know these?
fmulder13
Minneapolis, MN
An encryption key would be required to listen to encrypted transmissions. Unless you've been legally granted one, you're out of luck. As you look at databases, whenever there's an "E" listed, either by a talkgroup ("DE") or a conventional frequency ("FMNE") you're shut out of listening. Hopefully that helps. If there's anything else in the 800mhz range in your area that's not encrypted, the G4 is awesome.
Cheeseburgers
mulder had the correct answer. bob probably doesn't know... we can't automatically assume he's a bad actor.. which seems to be the case here on RR... particularly regarding encryption, it's actually pretty tiresome how everyone here is all "a hurrrr durr muh law enforcement needs encryption" yeah, we get it big guy. dude was just asking a question.
