GE LPE-200
Priority-One
Anonymous participant
Banned
Bronx, NY
Does anyone know if the LPE-200 is capable of emitting an "Alert Tone" for emergency purposes and does anyone know where i can get 6 LPE-200 radios programmed for conventional use?
GM
I'm not sure about the alert tone, but a search on eBay shows a number of LPE 200 radios both in the 800 MHz and 900 MHz band available for purchase. I'm not sure if you need any digital voice options such as Aegis or ProVoice, or just analog voice with them.
Priority-One
Banned
Bronx, NY
I have 6 of them for work. I just need programming and to find out about the work tone
Priority-One
Banned
Bronx, NY
Alert tone as in a tone that comes across the radio when a button is pressed to notify my crew in the case of an evacuation or emergency. I'm not sure if the LPE features this? I've heard of it on the XTS radios.
kb4cvn
Nowhere near a paved road, away from the maddening
All GE through Harris upper tier radios since the M-RK (and Orion) feature this function. (M-RK, LPE, J700p, P7100, P7200, etc.)
The radios will generate a single alert tone, or even a two-tone sequence to trigger pagers.
BTW:
All of these radios will also DECODE single or two-tone paging signals.
I have my all of vhf radios programmed to decode the 1050 Hz alert tone issued by the NWS during severe weather. This way, I can keep updated on adverse weather warnings, but not have to listen their broadcast unless an actual alert is issued.
Priority-One
Banned
Bronx, NY
Is there a software needed to issue the tone? Or can the tone be activated by pressing the Orange button? I am also in need of programming for 6 of these radios and possibly 6 more in the coming months. We are setting up a radio system in my work place with our 800mhz license at work. We require an employee alerting system since we have a 120,000 sf facility. We have an emergency response team and general operations and require all employees to be alerted by tone or message during an incident
kb4cvn
You just program the functions to the radio(s), and then you can activate the desired function with a button press. And yes, the RED (emergency button) can be retasked to do this function.
