Gloucester County 700 Mhz P25 Phase 2 !!
fireguyastro
delco,pa
Thanks phillydan I have a good scanner set up here in the house my next buy will be a apx but for now it'll do
jeff
St. Augustine, FL
Found this on Facebook, a local graphics outfit is selling these.
camco911
Wayne, Pa
I've loaded this in my PSR-800 and after a small glitch I have everything up and running. I live less then a quarter of a mile from the Gloucester County boarder and I'm having major issues hearing them clear, I'm listing to Camden County nice and clear and I thought that both systems are basically the same. Am I wrong to assume that?
adeangelo101
Will anyone be putting that under the Gloucester County online scanner as well? to separate from camden and vineland?
fireguyastro
delco,pa
I see the talk groups for fire have been loaded can some talk me through putting them on my 536hp
phillydjdan
Some observations from an APX user: I turned it on while driving home from Bensalem, PA to Delco, PA via I-95 South. I was picking it up well on the overpass but garbled once I got onto 95. Once I got into Philadelphia it cleared up again and was good the rest of the way down. One thing I have noticed is that the modulation levels vary significantly. While the dispatcher has quite low audio some mobile users blow your ear drum out. I suppose they did not implement noise cancellation in the codeplugs. Bucks County did and the sound is very nice. All in all not a ad system. Of course, your results will vary if using a scanner, but just figured I would add my results.
bstanleyWFD
New Jersey
Fireground Channels
Incase anyone was wondering, there is in fact 6 un-monitored Fire ground Channels for the new system. However they are conventional/digital layouts. I took the time and tracked all 6, included is a screenshot with how I programmed it on my scanner. These channels as I said are not monitored by the county, and they don't run off the antenna sites so they're only good for about a half mile in radius since they just work from radio to radio only, but I feel if your near the scene they are important to have as the County has asked for everyone to operate on them to avoid jamming the Fire 1-6 main channels.
FirePD
Boro Hts.
So would these be talk around channels?
fireguyastro
delco,pa
I mean unless you're close to the incident you're not going to hear them I don't believe they're repeated
bstanleyWFD
New Jersey
Correct, not repeated..but for anyone that would be responding to it or wants to be close to hear, it's good to have...other than that, yea your pretty much not going to be able to hear.
adeangelo101
MilAir, What feed are you broadcasting? We have been trying a few phone apps and been unsuccessful or hit or miss. Any help would be great.
camco911
Wayne, Pa
What freq's are the conventional 1-6 that's not digital? Would they be the same just Analog?
bstanleyWFD
New Jersey
I believe they are only digital, not analog at all...i'm still not a hundred percent familiar with this system, but they were discovered using a conventional mode, but are digital channels, obviously no encryption and not repeated...good for about a half mile or so.
adeangelo101
FIRE 1-6 on Bank A are "On System" digital. Bank B FireGround 1-6 are "Off System" digital. Bank B 10-15 are the Camden County equiv Fireground 1-6 conventional.
camco911
Wayne, Pa
That make sense! There might even be a chance that those Analog are Camden County's Freq for mutual aid purpose. Just a guess, they also could be the Digital Freq's in Analog mode.
