BCD325P2/BCD996P2: GPS
peewee008
Farmington MICHIGAN
Bought BC-SGPS serial receiver. Need instruction for settings after hook up. RJ14 into converter to 9 pin in rear. Conflicting instruction on baud rate ??
K4EET
Chaplain
Severn, Maryland, USA
Have you reached out to Uniden via the telephone or the place that you purchased the GPS receiver from?
Also, welcome to Radio Reference! I just noticed that this was your first post even though you subscribed last November.
peewee008
Farmington MICHIGAN
When I attempt to put in location, my longitude has a minus value -83.37.67.71W I can't find a way to enter a minus and when I leave it out I get a "out of Range" message ??
gh6406
Dalton,Ga
I don't believe that it needs the - . Just make sure it is E or W.
steener
SW Missouri
It should not be necessary to enter your location, only the locations for each system or site. However, if you do need to set a location, use the function knob to scroll all the way to the right. Then press the dot "." to switch between either N/S or E/W for the longitude or latitude. The minus is not entered. West (W) is minus longitude and South (S) is minus latitude.
Once you have the GPS physically connected to the scanner, you will need to enter the Settings Menu.
Then scroll down to Set GPS Format and select "Set Pos Format". It should be set to DMS.
Once you have selected format, press Menu a couple of times and select the "Set GPS Baudrate" menu item. For the Uniden GPS, it should be set to 9600 bps.
Don't forget to enable GPS for each system or site that you wish to track via GPS.
Hope this helps.
peewee008
Farmington MICHIGAN
Hope this helps.
Thanks a lot. I made those steps. Im at a POI setting. Should that be off ? Still getting no GPS input message. Maybe my location. I'm in a lower level. I can get signals on smart phone so I thought this not to be a problem. Appreciate your time and effort.
steener
SW Missouri
The POI setting is only used if you want the radio to notify you when you are approaching or at a custom point of interest. It should have no bearing on the systems or sites.
If the baudrate is set and the GPS unit is functioning, you should see "GPS" in the upper right hand of the display whether your are scanning or not. If it is not displayed, then it could be your location. You might move the GPS module next to a window to improve reception from the satellite. Unfortunately, the Uniden GPS has no indicator to confirm a signal lock other than on the radio.
86949
peewee008
Farmington MICHIGAN
I will do the relocate Later or tomorrow. If it works, then the question is how long can the RJ14 lead be if I extend it from one level to another?
Thanks again for working with me.
steener
SW Missouri
You're welcome. Hopefully, relocating to a more suitable area will solve the issue. As for extending the cable; I can't help with that one.
peewee008
Farmington MICHIGAN
relocated to area near window . Toggled baud rate (confliction Settings by Uniden and the GPS receiver..went with 9600) Still no action. Running out of ideas
steener
SW Missouri
You've reach the extent of my expertise with the GPS. Hopefully, someone else might have some other ideas.
Regards,
Paul
peewee008
Farmington MICHIGAN
Hope this helps.
Thanks for that. After following instructions, I get "out of Range" reading. Setting 42.46.15 N and 83.37.67.10 W In Michigan
ofd8001
Louisville, KY
Wonder if you might be using an incorrect position format with a few too many periods.
Set Pos Format
The option sets the position format for latitude and longitude.
DMS: DD⁰MM’SS.ss
DEG: DD.dddddd
