PSR500/PSR600: gre control demo for psr5oo/600
iMONITOR
Silent Key
S.E. Michigan
Mark if you are talking about wanting remote control monitoring. You want to download the remote control client that is in the link below.
Win500: WS1040, WS1065, PSR-500, PSR-600, PRO-651, PRO-652, PRO-106, PRO-197, PSR-310, PSR-410 Scanner Software for Data Management, Monitoring, and Control
[SIZE=+3] PSREdit500 Feature Lists (also provides Remote Control)[/SIZE]
Here's a partial list of the features of PSREdit500:
  • Full support for uploading and downloading the configuration of your GRE PSR-500, GRE PSR-600, Radio Shack Pro-106, or Radio Shack Pro-197 scanner's working memory.
  • Full support for editing of all of the object types on the PSR-500, PSR-600, Pro-106, and Pro-197.
  • Full support for downloading and uploading your data files to and from any of the radio's 21 V-Scanner folders.
  • Import conventional and trunked system data from the radioreference.com web service.
  • Import conventional and trunked system data from the radioreference.com database CD-ROM.
  • Import and conversion of the configuration of your Pro-96 or Pro-2096 scanner including all trunked settings, conventional frequencies and weather settings.
  • Import and conversion of the configuration of the GRE PSR-300, GRE PSR-400, Radio Shack Pro-97, Radio Shack Pro-2055, Radio Shack Pro-163, or Radio Shack Pro-164 scanners including all trunked settings, conventional frequencies and weather settings.
  • Import and convert your data file from PSREdit300 or PSR300DL into the PSREdit500 Format.
  • Import systems from other PSREdit500 ".bin" data files into your open configuration.
  • Modify scan list settings for a single object, or multiple objects with just a few clicks of the mouse.
  • Sort objects based on very flexible options.
  • Remote control of the PSR-500, PSR-600, Pro-106, and Pro-197. Using the PSRCtrl500 program included in the program archive.
  • Import ARC500 format files into PSREdit500.
mule1075
Washington Pennsylvania
Yes I know that but it is not a true remote control client. Not just virtual control with remote capabilities.
markbart
Spencer IN
gre software
Thanks everyone
What I meant was the software that was on the gre website as a download of the oweners manual. It also had the demo software on it.
