mikeh said:
can someone tell me in hell do i program this radio
the instuction suck . how do i just put in the
Talkgroups ids alone on a system
but i can not see how to proplem it
GRE you are going to have radio coming back if you put so info out fast
how do i program this radio how about some instuction
Software is coming, don't worry about that...
Press PGM
Press F1:NEW
Press F1:TGRP
Select the scan lists you want the Talkgroup in (use left and right to select the number, then the SEL button in the middle to turn that scan list on or off)
If you have already created the TSYS (Trunked System) Object, select that on the TSYS line using the right and left arrows and press the SEL key. If you haven't created the TSYS object, select the NEW option and press the SEL key.
Set the parameters for the system you want to monitor (System type, tag, frequencies, etc.) and the press the F1:Save key.
Now set the talkgroup number, tag, and any other settings for the talkgroup and then press the F1:Save Key again.
You should now have the TSYS object, and at least one TGRP object for that TSYS object... Press Scan and listen.
Mike
