I also want to add that many scanners won't tune to 220 MHz, especially the low-end scanners. It just isn't a popular band for much of anything. And for trunktracking scanners, they may or may not track at 220 MHz.
My contact seems to suggest it's going to be an LTR system. I'm told it'll be Motorola radios, with GPS and other features added to the radios. Details are hard to get when the person doesn't care about the radio system enough to pay attention to details.
I do know that the system has been contracted to Pinnacle and is at least partially operational, as the management have been using and testing the radios for some time now.
I think 220 MHz is a bad move, as equipment availability is very limited and so they'll be locking themselves into one manufacturer. 220 MHz is better than a UHF TRS at least, but at a sacrifice. VHF trunking would be ideal if they could have pulled it off.
Rumor has it that Verizon either owned or used the system, and traded the system to the Turnpike/Parkway in exchange for some of their frequencies. That would explain why the infrastructure is up already.
Hey fellas - I am thinking this thread could be related to the one below but not sure.
http://www.radioreference.com/forums/showthread.php?t=110620
Could be, I'd like to know if someone up north, and down south , near a GSP tower are hearing action on those frequencies also.
On the Toms River site I have not heard any conversations at all. Freqs=217.9000, 217.8000, 217.7000, 217.6000 with the CW ID on the .9000 channel. The channels pulse about every 2 or 3 seconds and its very annoying trying to listen to that for very long. Right now the .8000 channel seems to be down.
Is the Turnpike moving onto this as well?
NJDOT does have a ton of talkgroups on the NJSP system. Common sense would say get everyone on the state on the same system.
N2DLX...
To monitor this system what freqs would you put into the scanner and how would you monitor this system since it's 220 mhz. I'll be glad to monitor during the day just need some direction on how to set up the 996 radio.
Tony
N2DLX...
Thanks Tony
Listen from 216 - 218 MHz. No scanner will be able to follow the trunking, since it's an LTR Passport system. You'll hear idle pulses every 2 seconds or so (from the LTR controller), so you'll have to wait until you hear actual voice traffic to call the channel "active".
