Hamstick Dipole: Why is SWR changing when I move the coax?
k2mm
Scottsdale, Arizona
Hello,
I have been going crazy trying to tune my 20m hamstick antenna. It is mounted 3 feet away from my balcony and about 30 feet AGL. The antenna is not grounded, but shouldn't require it since this is a dipole. I used an antenna analyzer to adjust the antenna at 14.175MHz with a reasonable SWR. Everything looks great, so I moved the coax with the analyzer about 15 feet into my apartment and run the analyzer. The antenna analyzer no longer reports anything close to what was tuned when I was on the balcony. I am using RG8X coax, so I cannot imagine an interference issue. I have two loops of the coax secured below the feedpoint to the dipole.
I would really appreciate your suggestions as to what is wrong and how to fix it.
Thank you for your interest and time,
Mike
prcguy
You probably have a lot of common mode RF currents flowing on the coax shield and I suspect a good ferrite loaded choke balun will calm it down. You will have some VSWR because two short loaded hamsticks in a dipole config will not give a great match to 50 ohm coax, so the coax shield has become a radiating part of the antenna. You need to decouple the coax from the antenna and a couple of turns of coax will do nothing for the problem, you need a real effective choke balun.
Once you get a good ferrite choke right at the feedpoint you should be able to touch the coax or move it around with little to no change in VSWR.
Ubbe
Stockholm, Sweden
I've looked at some YouTube videos of hamsticks and all of them show people use the balanced dipole directly connected to an unbalanced coax. There's a reason to why there are baluns you can buy and use in these situations. The crude solution are a choke balun to at least get rid of the HF on the outside of the coax and could be a good solution if you work an antenna over several frequency bands and at high transmit powers, but a proper galvanic isolator in a transformer balun design are probably the best way to interface a dipole to a coax to not get distortion of the radiation pattern.
But that hamstick seems to most often be used with a grounded mounting piece that shortcircuit all signals from one of the elements and will then only work as a counterpoise, a GP antenna with only one ground plane element, and not as a full dipole that adds the signal from both elements. If that mount are used it needs to be properly grounded as the antenna doesn't operate as a dipole. Even when using a choke balun, a free floating ground on the antenna will reduce the signal levels to and from the antenna as the whole antenna will "move" RF wise with the radio wave.
/Ubbe
