Handheld with 800MHz and NFM
PluckyPleco
CM87
Would somebody please recommend a Uniden Handheld scanner that has 800MHz and NFM?
Analog only is just fine, we're a bit backward here in California's second smallest county.
Thanks,
PP
SteveSimpkin
Lancaster, CA
Thanks,
PP
All current Uniden scanners receive NFM. The least expensive current Uniden handheld model that covers 800MHz is the BCD325P2 digital scanner at around $370. The least expensive current analog desktop/mobile Uniden scanner that covers 800MHz (including analog trunk tracking) is the BCT15X at around $175. Unfortunately Uniden no longer makes a handheld equivalent of the BCT15X.
If cost is an issue you could always look for a used Uniden analog trunking scanner such as the BC-246, BR330T or BC-346XT.
