I am on a sailboat in the Bahamas with no way to get weather. My SSB receiver is not receiving very well.
I have a portable SSB receiver [Kaito KA1103]. I need it for weather reports, otherwise all I can do is look at the sky [not good].
I am not getting reception on the channels and times as I should be. A few times I've gotten faint weather forcast for a few seconds. I HAVE picked up a little Russian, French, Chinese, Spanish and a little from Australia. But not the channels I need.
I have a 30 foot wire that plugs into the antenna jack, and Ive run this up the mast. Hasnt helped. I read one user said he took 'some random wire and a connector [I assume the type that plugs into the antenna jack?] and grounded the shield on the connector'. And then he had GREAT reception. But I dont know what he means. Can anyone help explain that in laymens terms?
The antenna wire seems to be a single thin wire. I could ground to the engine block or the negative terminals on the battery. What is ment by ' grounded the shield on the connector'? I know what grounding means, but not the rest. Again, I need this in laymens terms, I am no pro.
Unfortunetly, I dont have a soldering iron or flux, but I could probably get some in a week or so. I do have wire crimps and a crimping tool. The only wire I have is the antenna and a bit of spare wire.
Any help would be great. I am leaving tomorrow morning at 6am, and may not have internet again for a while.
Thank you!
Thank you!
