HELP PRO-96!!
ThornyI
Holland, OH
When I turn on my Pro-96 it reads DPS LOAD PC/IF Port Flash Mem... I've read the owners manual and I am lost. Please help
Colin9690
County 21
APE282018
I looked on the RS support website for you, and the DSP from what i've seen is the firmware, or what the radio uses to work. If you have a PC/IF cable like you use with you computer to program the radio, you can go the radioshack.com, and so to SUPPORT for the PRO-96, and you can reinstall the firmware. I might be wrong, since i've never heard of this problem before. (Someone correct me if this post is incorrect)
Hope This Helps, :D
Colin9690
County 21
APE282018
Oh yeah, If you DON't have the PC/IF cable, you can pick one up at your local Radioshack, but first try RESETTING OR INTIALIZING the scanner. :D
ThornyI
Holland, OH
RE:
I have tired but it doesn't even come to the welcome screen, just says DSP Loading Boot: F1.0, then it goes to the screen I posted previously. It was programing fine without a cable. I'll just take it to Radio Shack and have them look at it. Anyone else ever had this problem? Note: The scanner will not reset.
Colin9690
County 21
APE282018
Ok. One last option before taking it to Radioshack is Initializing it. I believe you press 0 then 1 during the welcome screen. But I guess that's the problem since it wont even give you a welcome screen.
Yep. Your only option it looks like is to take it to Radioshack. They might even have to send it to the service dept. to fix it.
Has it been acting "weird" before it said this message?
ThornyI
Holland, OH
RE:
Nope, been working great till tonight, wanted to listen to MARCS, turned it on and got the message. O well, s*** happens. Thanks for everyones help.
loumaag
Silent Key - Aug 2014
Katy, TX
The message you are seeing is the message that is supposed to indicate that you are going to do an update on the DSP software. It is supposed to appear by pressing the <0> then <PRG> then <ENTER> buttons during the Welcome screen.
Before you run to RS, check to make sure that none of your keypad buttons is stuck.
ThornyI
Holland, OH
re:
I will do that, thanks. Is there anyway to get it out of that mode that you are aware of?
loumaag
Katy, TX
Re: re:
Normally, if you don't do anything for several seconds, it goes on. Hopefully it is a stuck button in your case. Maybe not.
