Help: Programming VX-3200U
austinm6
Northern New Jersey
I am trying to program a VX-3200U using CE-52E v4.5 I have made sure the com port is correct, but I cannot do anything to the radio and the software acts as if it doesn't even detect the radio. I am using a CT-104 cable, could that be the problem that I need to use a VPL-1 cable instead?
Thanks!
m-gerty
Miiddle TN
Isn't the VPL-1 the part number for the the whole cable set? And the CT-104 the modular half of the cable.
Is your cable a genuine vertex cable? There are several brands that use the same connector that will not work. What connector does your cable have on the computer end? Is it a DB-9 or USB?
What brand name is your cable?
m-gerty
Miiddle TN
I'm at work now, so I can't get to the ebay site to check cable. Don't know what version of windows you have, but you'll have to go to:
system ;
hardware ;
device manager ;
and under "ports-com-lpt" you should see your cable listed as com 1 or some other number. Main point here you need to check to see if your computer recognizes your cable and assigns it a com port number. Then in your radio software you must assign it the same com port number.If you plug it in to a different USB port the next time you use it, it'll change the com port number.
Edit: what I left out is your cable should have come with some driver software, which is usually specific to different windows types (95-98-me 2000-xp-etc..) another thing is some software isn't compatible with 64 bit computers.. Try the above and let us know what happened.
m-gerty
Miiddle TN
Sounds like bad/wrong cable. In post 3 you said it was an Icom cable. Not really sure if that's compatible with Vertex. At this point I would contact vendor and see about compatibility/replacement ..
m-gerty
Miiddle TN
The Amazon cable (this is the one I have) requires a serial port on your computer, do you have one?
I also have a cable from Kawamall, it works fine. I have the vertex cable because of the quality, can't go wrong with a factory cable. But it's useless if you don't have the serial port.
edit: my kawamall is for a serial port also, I have not tried their USB cable..
austinm6
Northern New Jersey
Thank you so much for your help. I do have a serial port, if you say the kawamall serial cable works I'll try that. I'm not planning on reprogramming the radios too often, so I don't want to spend $60 on the factory cable (plus Im cheap :D). I'll order the Kawamall cable and post my results when I get it. Thanks again for your help!
PACNWDude
I have been using the Kawamall cables for Vertex VX-3200/4200's as well as their Motorola CDM series cables for several years, they work fine.
However, if you have issues with USB to serial converters, I have had good luck with the Keyspan model of USB to DB9 adapter.
At one point I was even able to get a "Universal Motorola" programming cable from them that programmed pretty much everything from Maxtrac mobiles to PR1500 handhelds.....but it was an odd interface with an octopus type of cable connectors.
austinm6
Northern New Jersey
Well the cable worked perfectly thank you for your help! I just have one quick question, What CE version should I use to program my VX-3000U? this is the 3000u with the LCD. Thanks!
