Help with multiple amplifiers . please and thank u.
dlwtrunked
can someone tell me will this amplifer let me listen to vhf and uhf frequencies by amplifying them. Channel, Cascaded Ultra-Low Noise Amplifier
Definitely the wrong animal for your VHF/UHF bands. And adding amplifiers can be tricky if you have nearby signals which may require filters. What ever you are told, it can turn out to be an experiment that may or may not be successful and may require your time to optimize or you may just turn out to be lucky. I use a Pre-am in the >$100 range and various filters.
AngWay
Curious
Elizabethtown Ky
Fist some back story i have been using a generic noolec LNA for awhile but it died it was rated from like 20 to 2000 mhz.it done fine but small. anyways i'm getting rady to buy a new one can u all look at these and tell me what i should get? and please done say the same one i had it was junk in my book. ALSO I LISTEN TO VHF and UHF and some 800mhz so these need to cover those; btween 150mhz to 450mhz
OK here goes up first
1 Nooelec SAWbird+ ADS-B: Premium, Dual-Channel, Cascaded Ultra-Low Noise Amplifier
2 LNA-VHF-B Pre-Amplifier
3 Tangxi amplifier
4 Oumij1 amplifier
5 Active RF Isolation Distributor it says this only goes to 150mhz but can be pushed o 300mhz but it still wouldn't sereve my purpose wuold it?
6 High Impedance Amplifier Impedance Conversion Device for SDR Walkie Talkie for HackRF for One Donut Antenna would this reach 150 to 450?
7 Signal Amplifier 100k-6GHz Full Band Low Noise 9037BAT-LNA RF Amplifier High Linearity Ultra-Low Noise Gain Block Amplifier now my fav but it's so cheap makes u think its junk but what do u all think?
8 High Impedance Amplifier Small Loop Antenna 1Hz-300MHz Doughnut Short Wave Antenna 5V 600mA for HackRF One for SDR Walkie Talkie also cheap but differnt in range
9 RF Amplifier High Flatness Amplifier 10M‑6GHz 20DB Gain LNA RF Drives Receiver Low Noise Amplifier for FM Radio then there is this one which looks pretty nice
10 Nooelec Lana - Ultra Low-Noise Amplifier then there is old faithful whch i have owned before i lasted 6 months and stopped working.
if any of u have any time at all could u please look at these amplifiers and tell me which one should i get to better hear my VHF and UHF and 800mhz? i mean thre is 10 of them here and i just want the best one that will give me the best performace and strongest signals. Thanks everyone..
and kevinC i i hope iposted this in the r
AngWay
Curious
Elizabethtown Ky
i use filters.. can u send me the ones u use the pre amp in teh 100 range id like to reseach it
dlwtrunked
Ubbe
Stockholm, Sweden
can anyone look at those i listed that has experience and tell me which one i should get?
It will depend on your unique local RF situation. And you will always need to attenuate the signal from an amplifier that has 15-20dB gain to not overload a receiver.
/Ubbe
dlwtrunked
Believe it or not i use a amp from amazon for tv antennas that works great with a 24 db. (The crimple co) $34.97
I have used TV antenna amps before. They can work but vary in performance and often coverage and generally in my comparison tests failed against other types.
dlwtrunked
/Ubbe
Just to be clear, on an SDR radio you can do this by adjusting the gain of the SDR rather than adding an external attenuator.
  • Like
Reactions: wtp
Ubbe
Stockholm, Sweden
Yes, but it still has some components before its internal attunator that affects the overload value. At max gain of a R820T2 dongle that are 50dB it's IP3 are 42dBm and at its lowest gain of 0dB its 35dBm. So 7dB worse at lowest gain. I don't know how signal/noise ratio changes, its noise figure, as the spec sheet only says its 3,5dB at max gain but probably gets worse at lower gain levels as specs usually show the best value. But it's true, for an SDR you can usually adjust its own gain to compensate for a high gain pre-amplifier.
/Ubbe
bharvey2
How far away are you from the systems you wish to monitor and what kind of terrain exists between you and the system? I do most of my public service monitoring via SDR now and found that a suitable outdoor antenna typically provides better results. Also as dlwtrunked and Ubbe pointed out, you can usually adjust gain within the controls of the SDR software. Be cautious about adding inline amps. They are just as likely to introduce noise and overdrive your receiver.
prcguy
A basic statement to memorize and never forget is, “an amplifier is not a replacement for a good antenna“. An amplifier is ok for making up gain before a splitter or if you can place an amplifier right at the antenna you can actually improve reception. Otherwise in many cases adding an amplifier will only cause reception problems.
dlwtrunked
/Ubbe
I have never found the additional components to be a problem. I do use filters and have multiple transmitters 0.8 miles away.
