SDS100/SDS200: Help with programming a system
fasteddy64
Gulfport, MS
Trying to get this system into a favorites list, but when I go to the database I can not find it anywhere.
Any suggestings?
hiegtx
Dallas, TX
Go here …
Edited to add that the site screenshot you posted says that system transmits on C4FM which may not be decoded on the SDS100.
Then I must be listening to a "ghost" system, since I can hear the Fort Worth branchof this same system.
Any suggestings?
I have no idea why that system does not show up in your area in Sentinel. But it does show up under County Systems for Tarrant County. Just append it from the database there, then whittle it down to size to only the parts that interest you.
dave3825
Suffolk County NY
If you are using sentinel, choose add channels on range. Then put in your zip and make sure service type military is checked along with any other service types used on the system you wish to hear..
Or like @hiegtx says, append from Tarrant County TX.
hiegtx
Dallas, TX
Dave,
For some reason, that system is not in Sentinel in Ed's area, and in fact, it does not show on the 'trunked systems' list for Mississippi. I'm not sure if Sentinel would grab it with location & range, since the system is listed under the county level, not National.
TexTAC
Does it show that system in Sentinel under Harrison County Mississippi?
TexTAC
Ok. Then like hiegtx said you should be able to find it in Tarrant County Texas. I have the Fort Worth systems programmed in my SDS 100.
fasteddy64
Gulfport, MS
Thanks Steve and all, I went to Ft Worth, found the system I wanted and appended it to my favorites list.
All is well
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
Wrong! System is P25 Phase-II which can be decoded just fine by the SDS100. Don't let modulation (C4FM, CQPSK, etc) throw you off here. Yes, Yaesu System Fusion uses the same modulation which cannot (at time of this posting) be decoded by Unidens. See FDMA paragraph here for a better description
dave3825
Suffolk County NY
Dave,
I am on Long Island in New York and when I did add channels on range, it pulled it in no problem. It does also show the site the OP posted in the pic. I did use a 50 mile radius so it must have grabbed it from either CT or NJ since there are no sites in NY.
As for it not showing in Harrison County Mississippi within Sentinel, it does not list the other site in Mississippi, Lauderdale either but @ProScan has them both listed correctly.
I would reach out to @JoeBearcat since Sentinel is the program not showing the system.
All is well
Lol, all is not well if the system is not showing in Sentinel for other users in Mississippi. :)
hiegtx
Dallas, TX
I think this is an RR Database issue, not one for Joe Bearcat or Sentinel.
When this was first discussed yesterday, the system was not listed under Ed's county, nor was it in the overall list of trunked systems for Mississippi.
However, I see that, as of today, the Gulfport & Lauderdale sites are listed under their respective counties. One of the DB Admins corrected that yesterday evening. However, the 14C system still is not listed among the list of trunked systems for the state. So there is still work to be done.
tvengr
Well Known Member
Baltimore County, MD
Site and talkgroups and show up on Alabama trunked systems. Look under Alabama in the database.
Naval Construction Battalion Center Gulfport Talkgroups
Naval Construction Battalion Center Gulfport maintains and operate facilities and provide services and material in support of Naval Construction Force Units, to include Amphibious Construction Fleet Units, the Maritime Prepositioning Force (Enhanced), and other fleet and assigned organizational units deployed from or homeported at NCBC Gulfport. NCBC Gulfport is also home to the Atlantic Seabees
DECHEXModeAlpha TagDescriptionTag
2891070eeDNCBCG Fire DispFire DispatchFire Dispatch
2891570f3DNCBCG PoliceDispPolice DispatchLaw Dispatch
29802746aDNCBCG Fire DispFire DispatchFire Dispatch
hiegtx
Dallas, TX
It may be under Alabama, but the original county in question, Harrison, as well as the one Dave mentioned (Lauderdale) are in Mississippi.
One of the DB admins has now linked the system to the two Mississippi counties, but it still is not listed in the statewide list of systems.
I originally suggested appending from a Texas County because I knew it was linked there.
hiegtx
Dallas, TX
Mississippi was missing from the system location states; I added it. Did that resolve your problem?
Thanks for making the correction.
The OP resolved the issue by appending the system from another state. Once Sentinel updates this coming week, everything should be on the correct path.
JoeBearcat
Inactive member
Uniden Representative
If there are no TGs, there is nothing to monitor.
Some have requested that such systems be added in ID SEARCH mode, but that
is not something that has been changed (and may or may not ever be changed)
