I live in Edina and bought a used Radio Shack scanner, programming cable, batteries, etc. The seller programmed in all the codes for me and the scanner really does not work that well. It will garble, or go to static. A friend of mine in Detroit said I should buy a used Motorola XTS2500 radio and I did on E-Bay. It came with a couple of batteries, charger, and a speaker mic. The seller said I needed a programming cable and I found a cheap one since i was told the original ones are not cheap!. He sent me the software, a file called a "system key" and a note that said RID#336003 it also said that number may have to change. and finally instructions on how to program it up. He said this way is so much better than any scanner out there and I would be happy.
So I get all the stuff, install the software on my computer and follow the directions on entering the frequencies and codes. I told the software where the "system key" is since it would not let me generate a new trunking system. After a couple of hours I thought I figured it out, what a mess!. So I get it to have Edina Police and Fire, State Patrol and a agency called Violent Offenders Task Force since it maybe to listen in case I happen to hear my neighbor's name come over
. All appeared to be normal but when I turn the radio on after I programmed it the little LED on the top flashes a couple of times and then nothing ever happens. The display shows the name of the channel I entered it as and can and what little that will come in over the scanner never comes out over the Motorola radio. For testing I would press the talk button but it just emits a loud tone.
My buddy says he does it in Detroit to listen to them and it works great and I must be doing something wrong and suggested this site for help. He gave me a new RID# to use but all the radio does is beep and the display says "OUT OF RANGE". All this mess to listen to my local police and streaming is not possible since the feeds are delayed so they can be censored (nice country this is) and my cellphone woulds just drains the battery faster plus he said it's loud coming over the speaker mic and some people might think your a cop and leave you alone. Can anyone out there help on what's going on?. I have about $500 invested in this mess and the seller does not take returns. i e-mailed him what was going on but he said it was working great before he sold it and I must be doing something wrong.
