Help With StarCom21
XSSkeet
Hey all
I recently purchased a Uniden BCD536HP and have been using the Sentinel software to create favorites lists. I live in St Clair county and am trying to add ISP District 11 only.
If append the "ISP District 11 - Collinsville" talk group folder to a favorites list it adds the Dist 11 talk group folder, but also pulls dozens and dozens of folders named for locations across the states. I assume these are all control frequencies, but nearly all the locations are outside of the District 11 area.
If I leave all these folders in the list it seems takes a long time to scan through them all. I have gone through and deleted or set to "avoid" all location folders that I believe are outside of District 11 and it speeds up scanning dramatically, but I'm afraid I may me missing some local communications.
If I delete all the folders except for the District 11 talk group folder will the scanner know the control frequency with just the talkgroup info? Should I leave all these folders in the favorites list or was it an acceptable practice to remove the folders for locations that are clearly out of district 11 area?
Please be kind. I have spent over 20 years reading fairly complex wiring diagrams to maintain aircraft electrical systems, but for some reason manually programming a digital trunked system seems to be beyond my comprehension. I long for the days when my BC780XLT was king.
tvengr
Well Known Member
Baltimore County, MD
Use the St. Clair County Simulcast site only. Remove the letters "c" and "a". That indicates the control channel and alternate frequencies.
3 (3)059 (3B)St. Clair County - SimulcastSt. Clair, IL851.075851.175851.225c851.5625a851.700851.800852.0875
852.1625a852.1875852.5875852.700852.750853.1375853.6375
853.750853.850857.7375
hiegtx
Mentor
Dallas, TX
Hey all
That's one "gotcha" of the Sentinel software. If you try to append one or more departments from a trunked system, it automatically adds all of the sites in the system, including those far out of range.
You should only keep the site(s) that are in range from your location, as those would be the ones that carry radio traffic from the various towns and agencies around you.
tvengr has already suggested removing all but the St Clair County site. However, you may be unsure as to whether one or two other sites might be useful. The sites are not always named after specific towns or counties. Some may be named for a local road or hwy, or a geographical feature such as a hill. Looking at the STARCOM21 system in the database, if you click on the County header in the sites section, you can resort the list of sites by the county they are in, which makes it easier to spot what you may need to remove or keep.
For the sites that you want to drop, you can do that by using the Favorites List editor.
Or, in the Sentinel initial screen, if you click on the system name in the left window pane, you can see all the departments and sites in the right pane. There, you can hold down the <Shift> key, and click on the first, and last, site in a consecutive group, highlighting the ones selected. Then, if you <Right> click in the selected group, you can choose Remove from Favorites List from the poop-up menu to delete them en masse, You can also hold down the <CTRL> (control) key, and pick and choose sites individually. Then, with them still highlighted, right click and select Remove to delete from the list.Once done editing your list, then b sure & write the corrected Favorites to the scanner.
XSSkeet
Thanks all...That was helpful. I was able to narrow it down from about 50 to the following few sites that are all in District 11 territory.
I wish there was a way to tell exactly what frequencies a particular talk group ID uses. Perhaps a mobile unit will switch to the frequencies of the closest sites? I figured out how to use the wifi option of the scanner to send to my phone's Siren app. That app does show the control frequency when it receives a transmission, but it does not show on the scanner.
Thanks again
St Clair County Simulcast
Madison County Simulcast
Columbia
Waterloo
