If you want to hear City-Wide your out of luck…it’s encryptedSent a PM...
Sent a PM...All or any sensitive channels cannot be monitored as well as the sheriff’s office. All USF tac channels are encrypted
I'm aware.If you want to hear City-Wide your out of luck…it’s encrypted
The real deal on what you are hearing is sometimes a radio will drop the encryption key by accident or improper loading.The SO has always had encryption even at the start of the 800 system in 95. It was only used for special situations and usually they just relayed on Aegis at the start and Provioce later to restrict monitoring. On portable radios whether GE Erickson, Macon, or Harris if you push the left and right top buttons it will force the encryption key to drop. It’s useful if you’re sending that radio to an outside vendor for repair. Most of the time it happens accidentally when you get excited and push a lot of buttons and don’t know what it will doMaybe you can educate me a little... are these channels blanketed by Encryption at the server... or can a Deputy accidentally not have encryption enabled on their radio?
I ask because we caught some unencrypted transmissions -- but I also catch TAC channels popping for a millisecond on my SDS100 before the scanner moves on....
I've been trying to get this set up for over a year on my apx. I'm used to the protocols for the M systems. Not the Harris obviously. Any suggestions?Using NAS on an apx im hearing everything else but HCFR channels except disp and cad
TT is still in the clear...Has anyone noticed Temple Terrace has gone to or trying Encryption
I believe I have it figured out. Seems to be a radio issue that was solved by turning the radio off and on again.I don’t know if it’s because of the massive volume of calls but I’m only picking up dispatch and tac 2 despite them using every tac channel up to tac 13.
What radioI believe I have it figured out. Seems to be a radio issue that was solved by turning the radio off and on again.
Someone please correct me if I'm wrong, but all the frequencies are control channels at randomHad a question, I see that RR has like a lot of frequencies listed as control channels and was just wondering if there is a dedicated control channel or if there is some type of schedule where it cycles between all those control capable channels. It might be a confusing question so just let me know if I have to elaborate.
Does anybody know what's going on here? There is a constant stream of P25 data going out over 774.38125 MHz on the East Site, but the control channel is at 773.23125 MHz.EDIT: Seems to be there's some sort of control channel data bleeding over one of the frequencies on the East site that is not from the system.
SYSTEM:32D[813] NAC:00A[10] RFSS:DE[222] SITE:DE[222] LRA:0A[10] STATUS:ACTIVE RFSS NETWORK CONNECTION
774.38125c
774.89375c
851.1375c
851.3875c
SYSTEM:32D[813] NAC:00A[10] RFSS:02[2] SITE:02[2] LRA:0A[10] STATUS:ACTIVE RFSS NETWORK CONNECTION
769.55625c
770.58125c
771.30625c
771.75625c
771.98125c
772.48125c
773.23125c
773.73125c
851.5625
851.825
I'm in polk county and I'm getting site 222. I wonder if that is for Air Ops? 2 TGs are patched with 222. TG 15003 & 15004Does anybody know what's going on here? There is a constant stream of P25 data going out over 774.38125 MHz on the East Site, but the control channel is at 773.23125 MHz.
