HP-2: Home patrol 2 and sd card
ve2que
quebec
My home pat 2 is having sd card problem, try to format, try reinstall sentinel, It still say the same thing as in the picture, and now scanner does not want to write or read as soon as I power up a message say remove battery one minute. Can-it be a conflit between sentinel and ARC for home patrol programs?
fxdscon
¯\_(ツ)_/¯
That exact error message usually indicates that Sentinel is having a problem with your Window's regional settings that are using commas instead of decimal points.
Search for "region" in the Windows search bar and choose "set regional format" and change the regional settings to Canadian - English so that the decimal point character is represented as a dot instead of a comma. Then reboot the computer and try Sentinel again.
ve2que
quebec
God more it goes more it became complicate or I getting too old.Thanks, but now I have to find a way to fix the sd card, because the sd card have been formated but may be will find a way to keep the scanner open the time to update the sd card, I tought it was the sd card who was in trouble. Thanks for your help.
André
fxdscon
¯\_(ツ)_/¯
André
If you have formatted your card...... New (or newly formatted) SD cards will not be recognized by the scanner until you use the "Clear User Data" function in Sentinel.
With your card in the scanner, put the scanner in "Mass Storage Mode" (or use a separate card reader if you have one.... much faster). You may need to connect the scanner to your computer before turning the scanner on to enter mass storage mode.
Download this utility (recommended by Uniden) then use it to format the card.... use the "overwrite format" option.
Then Use Sentinel's "clear user data" to restore the proper operating files to the card. (click the "show all drives" box when the clear user data utility starts). Then write from Sentinel to the card to restore your info to the card. Re-boot the scanner (or if you used a card reader, put the card back in the scanner and turn it on).
goldwing24
virginia
I have a new home Patrol 2 with the same issues ever called messages even with the card that comes with it you get a error message soon as you remove the card it will not working work anymore I have reformatted FAT32 I have used the Sentinel software at nothing seems to work always getting the SD card error messages like I said if you take out the card and reinsert the card without even doing anything it will come up SD card error even with the original SD card software on it problem being is the unit itself has internal problems that Uniden apparently will not fix or address I now have a paperweight does not work at all has anybody else had these problems with removing the SD card and reinstalling it and getting the error message my home Patrol 2 up to this point was working when I went to remove the original SD card that came with it and put it back in it quit working and got the error message era era quit working and got the
Ubbe
Stockholm, Sweden
If you get that database error then change the regional settings in Windows and if not using a USA country setting then change the decimal point from comma to a dot, or use that Canadian setting. If you get another type of SD card error then do that "Clear User Data" from Sentinel and write your programming file back on the SD card including an updated database.
/Ubbe
goldwing24
virginia
Have tried all of that no success the original SD card that comes with the home Patrol too when I went to remove it and put it back in it came up SD card error message I could not use a formatted new SD card because it also came up SD card error I do believe it's something wrong with the home Patrol 2 inside like I said it was working out of the box then I decided to add a 8 GB card it did not work it came up error message I put back the original SD card that came with my home Patrol too with the original software on it that comes from Uniden and it came up error message SD card error message please remove batteries for 1 minute that's all it does no matter what I do formatting doesn't work redoing the data on Sentinel doesn't work pretty much stuck has anybody anybody found a way to get past that I'd appreciate it
It's me again I also cannot get it to recognize the computer it will not come up on a computer when I plug it in from the home Patrol to unit to my computer because it will not go into Mass storage mode
Has anybody that owns a home Patrol too found any fixes for these problems I would greatly appreciate anybody that could help me with this problem
fxdscon
¯\_(ツ)_/¯
Start with the scanner TURNED OFF...
Connect the cable to the scanner and to the computer with Sentinel running, THEN turn the scanner on.. it should go right into mass storage mode. Then use the clear user data function in Sentinel, and select "display all drives" box in the clear user data window and follow the prompts.
If no luck with that, replace the card with a new one and run the "Clear User Data" process again..
dmfalk
Do you have the card inserted correctly? Is the card formatted to FAT32?
goldwing24
virginia
When I take out the original SD card that came with my home Patrol to and try to reinsert it without doing anything just remove it and then put it back into my home Patrol too it comes up with SD error message please remove batteries for 1 minute and that's with the original card that came with the unit it won't let me get into mass storage with that message displayed there is no mass storage why it's stuck in SD card error message with remove batteries for 1 minute so you can't do anything through the scanner has anybody removed their SD card from their scanner and tried to reinsert it without getting an error message because all I do is get the error message please remove batteries for 1 minute
Ubbe
Stockholm, Sweden
Does the SD card go into its slot with a click, so that it's inserted fully?
Do you have a SD card reader or a laptop with a reader so you can check that the new SD card can still be read OK when it has been in the scanner and haven't got any corrupted files?
/Ubbe
goldwing24
virginia
Yes the SD card slides in with the click in the home Patrol unit and yes I have a card reader and it does read all the files are on the I'd like to thank you for answering me if you come up with anything please let me know SD card from The Sentinel software all the files are there but like I said when I remove the original SD card that came with the home Patrol and reinsert it with the click it will come up SD card ever please remove batteries for 1 minute every time and that's what the original SD card
goldwing24
virginia
Has anybody out there had any success in removing their home Patrol 2 SD card and reinserting it and having it work properly or does it go into an error code message saying remove batteries for 1 minute
fxdscon
¯\_(ツ)_/¯
I have removed the SD card quite a few times from my Home Patrols and have never seen that issue as long as the card is re-inserted all the way until it locks in.
goldwing24
virginia
It's on the home patrol 2 if u take the SD card out of the unit and reinsert it you get an error message all the time
dmfalk
I've had it happen just once, in the, oh, 7 years I've owned my HP-2.... Just once. :)
fxdscon
¯\_(ツ)_/¯
Having several of the Home Patrol scanners (1&2) in constant use since they were first released 10-12 years ago, I can assure you that the issues you are having with just removing and replacing the SD card do not happen on a routine basis.
Watch the video at the link below and be sure you are inserting the SD card properly:
goldwing24
virginia
I have watched that post twice I watched that video post twice the second I take out my card from my home Patrol and put in the reformatted home Patrol SD card that I use the Sentinel software with it will not work it says SD card error take out the batteries wait a minute and put the batteries back in and that does not work either
dmfalk
Is the SD card bigger than 32gb? (Shouldn't be.) Is it formatted to FAT32? (Don't format with default settings.) Are the contacts (card and card slot) dirty? (Shouldn't be!)
Usually, the biggest culprit is the card format, if the card is otherwise readable on the computer! :)
