HP-2: Home patrol 2 and sd card
goldwing24
virginia
Or will I get the same dreaded error message remove batteries and power for 1 minute and then put back in batteries and restart it that's the error message I've been getting
jtwalker
Gettysburg, PA & Fenwick Island, DE
A properly prepared Sandisk 32gb sd card will work.
And you can place the card directly in pc running Sentinel (or other programming software) to program the scanner, without need to get scanner into mass storage mode. Then put card back in scanner.
goldwing24
virginia
Thanks for the advice I appreciate it but it doesn't work that way either still getting the dreaded take out the batteries for 1 minute error message I'm pretty much at a loss now cuz apparently I'm probably the only one having this problem according to what people are telling me nobody else has had this problem unless they're just not telling the truth
jtwalker
You really need to use some punctuation and line breaks. Very hard to follow what your are trying to communicate.
Does the original SD card work? Do you get the message about battery/power with original?
goldwing24
virginia
Your answer does the original card work as the card work the answer is no I get the dreaded take out the batteries remove the card for 1 minute put back the SD card and batteries I don't know if anybody out there is having the same issues with the dreaded SD card error message on the home Patrol one and two but I appreciate your feedback and can you let me know do you own a home Patrol too and if you do how are you getting it to work have you ever taken out your SD card from yours I'd like to know thank you
N0ZQR
Nebraska
goldwing24:
To me it sounds like the carrier for the SD card will not let the card "stay" in the scanner properly.
My recommendation would be sent it in for repair.
Ron
goldwing24
virginia
If anybody else out there has a home Patrol too that is having this error message problem please let me know what you did to fix it
dmfalk
This sounds to me like this user doesn't understand SD card formatting, and that the default format a card comes as is NOT the format the HP-2 can use! Most new SD cards are formatted as "exFAT", and need to be reformatted as "FAT32", or the HP-2 won't function. When you format an SD card in Windows, the format utility has a drop-down menu for the type of format, usually saying either "default" or "exFAT". Click on it, and select "FAT32", and then click OK. In Sentinel, you then need to click on "Erase card data", then "Write to Home Patrol".
Remember, the scanner cannot read a fresh SD card by default, BECAUSE of the format, and it needs a fresh write of its file directory in order to function, once properly formatted!
goldwing24
virginia
Well thanks for the information but I've done all of that the FAT32 the formatting and it will not work even with its original card that it came with and I do know what I'm doing I just want to know if anybody out there is having problems with theirs when they remove there original SD card
MUTNAV
OT quick question... Are you using speech to text software or other aid to write your posts? No problem if you are, just wondering.
Joel
MUTNAV
Yes, at the time cost me $68.00 plus 18.00 shipping to get it there.
Actually I was asking about goldwing24, as that might explain the punctuation and run on sentence issues.
Joel
goldwing24
virginia
Will I see that well have been reading and now I see that the SDS 100 and sds200 also have the SD Carriage area error so you cannot remove the SD card otherwise you left with an unusable unit just like the Uniden home Patrol two you've got to leave that card in the second you try to remove it it fails every time that is a fact
fxdscon
¯\_(ツ)_/¯
No, it's not a fact. Your assertions are absolute nonsense.
goldwing24
virginia
Well it's not nonsense I did call tech tech support at unit den and they indeed it made it to having an SD Carriage error message on their 100s 200s and they're home patrols 1 and 2 and you have to send it in for a SD card Carriage replacement so it's that's the fact thanks a lot for nothing out there you guys
