HP-1: homepatrol issues
ronnielewis18
Zebulon, NC
Hi, I just bought a homepatrol 1, I live in franklin county nc, I enter zip code and I'm not hearing anything from franklin county, not even surrounding areas, am I doing something wrong
joeuser
The Wretched
North Central Kansas
Have you installed the software on your computer & updated the software & the database?
NWI_Scanner_Guy
Dyer, IN
Also make sure you have the service types turned on for what you want to listen to.
ronnielewis18
Zebulon, NC
homepatrol
Let us know how things went, quote this post when you reply and we can help further, if needed.
Ive done all I know to do, still nothing from Franklin County, im hearing all counties around me and nchp, but nothing from franklin county, about ready to send it back, thanks for any help!
joeuser
The Wretched
The only thing I can think of, assuming you did everything right with updating & uploading, is that Franklin co nty is using a non-monitorable system or its encrypted. Have you checked your state's database here on RR? I ask because it may explain a lot. Also what do you want to listen to? Law? Fire, EMS? If you are hearing the SP you should get all law in your zip area, what is your range set to? Default is 30 miles away... but if its 31 or more it won't put Franklin in your list. Range maxes at 50 but its really determined by your antenna & location (geography, environment, etc)
Voyager
First step is to update the database in Sentinel, then send it to the scanner. Then try again. I haven't seen that you have tried that yet.
ronnielewis18
Zebulon, NC
homepatrol
yes i have updated to computer and sent to scanner, i can hear the broadcast on my ph app. there is a guy in wakeforest area streaming it so i know it can be monitored, i just dont know what to do now, i guess it will go back to the store, is there anyway to upload freq. from this site to the hp1?
Voyager
Uploading from RR to the scanner is the first line of what you said you did.
Next, check to make sure all the service types are on.
Also check to make sure the range is high enough to cover the area you want to hear.
ronnielewis18
Zebulon, NC
homepatrol
I uploaded sentinel using the usb cable from the computer to the unit, I was not aware I could download from this site, how do I do that or am I misunderstanding something. Ive had scanners since 1974 but this is my first digital scanner, I chose it because of the simplicity that was adverstised. Thanks for the help
Voyager
You're not understanding that the database you update comes from RR via Uniden.
So, if it's on RR, and it's monitorable, it's in the Sentinel database.
ronnielewis18
Zebulon, NC
Ok I got ya now, I've tried everything I know to do, I know it will monitor franklin county I hear it on my ph, maybe I will return it and just listen to ph, thanks for the help!
ccs247
Hilo, HI
Franklin County is listed as a five site, VHF, P25 simulcast system. Your scanner may be experiencing simulcast distortion. Have you tried moving the scanner to different locations?
hiegtx
Mentor
Dallas, TX
Yes I have done everything but get a 800mgz antenna, if that don't work I give up, thanks
Since the system you are trying to hear is Vhf-high, an 800MHz antenna would not be the best choice. You would be better served with one that was more useful on Vhf, such as this one.
Diamond RH789 SRH789 Antenna
That antenna is available with an SMA mount (the SRH789), which will connect to your HP-1 without an SMA->BNC adapter. It has a swivel base, so that you can connect the antenna, then extend it upright. It has markings showing how far to extend it for various bands you wish to monitor. I used this antenna on my HP-1 when I spent a month in the hospital in 2013. Worked very well for the wide range of systems here in the DFW Metro area.
