How Common Is The Radio Reference Import Error Issue?
bberns22
West Chester PA
Worked for me perfectly running latest version of Windows 10, I also run PPS as administrator. My RR password contains a mix of upper/lower case and numbers...
bberns22
West Chester PA
I suggest everyone share their Windows version to see if there is a common thread. Also including my basic system summary
OS Name Microsoft Windows 10 Pro
Version 10.0.19041 Build 19041
Processor Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz, 3600 Mhz, 8 Core(s), 8 Logical Processor(s)
Installed Physical Memory (RAM) 32.0 GB
kd7jfv
Bend, Oregon
Just to be clear, the “offline” radio reference import does work! It’s just the login that is not.
buttaik
The issue resolved itself when I did the following (thanks to another user in a different Unication thread):
Close PPS software
Under the ProgramData\Unication file directory, rename the RadioReference directory to something else (like RadioReferenceOld).
Open PPS Software
Click Import Radio Reference icon in upper right of PPS software
Allow the process to complete. Took 15 minutes or more to complete (keep pc from sleeping while this process completes).
Once completed the RR import worked fine for me.
Hope this helps.
burner50
The Third Variable
NC Iowa
Just tried it for the first time. Won't take my username / password. Quadruple checked both, changed my password so something less complex, same result.
  • Like
Reactions: qc
bob550
Albany County, NY
This is shot in the dark and I have no idea why this would matter, but for those of you having trouble, are you subscribed to an 180 day, 360 day, or 720 day plan?
burner50
The Third Variable
NC Iowa
None of the above. DBA Access.
n1das
Nashua, NH
I have not had any trouble logging in and the PPS crashes when I try to use the RR Import feature, same as what others are reporting. I am using PPS version V03.16.21 and my brand new G5 UHF-D w/DMR has V1.31 firmware.
I worked around it by downloading and saving what I wanted from the RR database as an Excel file. Importing to PPS from the Excel file worked. It's the RR Direct Import that's not working as others have reported.
Good to know that Unication's SW team is on it. :)
rr60
Working fine for me after some effort and reading and rereading this thread.
The initial download took almost 30 minutes, this first time I stopped it at 15.
I then followed the renaming folder suggested in this thread and downloading new driver.
Nice improvement, thanks Unication.TW . Nice to see all the product support.
