How Common Is The Radio Reference Import Error Issue?
Webodisk
Silent key.
Virginia Beach,VA
What version windows are you running ? I have not upgraded to the latest version and some folks reporting problems after they upgraded to the latest version of Windows 10
jpb
I never had a problem logging into RR using V0.3.16.21, but I tried to import Maryland FiRST and it imported all the UNSELECTED TGs! I downloaded Beta22, and it was better, but it still did not catch all the TGs I selected. I see the popup warning about "invalid info or duplicates will be ignored", but that tells me nothing about what fails. I hate to admit Moto CPS has any redeeming value, but it tells you exactly what info is invalid. I suggest Unication do the same, and give you a chance to fix the fields or cancel.
Am I missing something?
jpb
To clarify the previous post, I have tried several attempts at reimporting FiRST. I will give the benefit of the doubt on control & alternate channel import (48 sites, 96 control channels), but I have not scrutinized them line-by-line. Clearly, no matter what you do with talkgroup import, even when trying to import *all* of them, the TGs I select and the TGs that actually import are not the same. Kudos to Unication and @Uni1 for spending the effort to do this, but it's not usable yet.
jpb
Has anyone else had the same problem of the talkgroups you select not being the same as what actually imports from RadioReference?
robert8450
Grand Rapids, Mi
Ok... here is the SOLUTION...
Your issue is most likely due to not allowing the first initial download adequate time.. I too stopped it after 10 minutes thinking that it had crashed. When you do that, you screw the connection and future attempts won’t work.
I tried several things as mentioned in this thread and nothing worked until....
1. uninstall your PPS software
2. Install it again
3. Connect your radio, download your profile.
4. Click the connect to RR database button (PPS will think this is your first attempt) and D/L the whole thing again
5. WAIT FOR IT.. mine took 28 minutes to fully download the database.
from that point it will work from then on - Once you have the whole DB downloaded to your computer, you can Then choose “offline” for Faster “downloading to your PPS”. Basically you only need to connect and download from RR periodically to update your database on your computer.
burner50
The Third Variable
NC Iowa
That has been posted several times previously, and as stated previously, that is *NOT* the "solution. The solution is to use the beta software that was released that fixes the issue.
  • Like
Reactions: qc
N6ML
There are at least two real issues, and a third possible user-generated issue:
  1. PPS actually crashes when trying to use the import feature - fix is in a Microsoft .NET framework update
  2. Username/password not accepted when attempting to connect to RadioReference - fix is PPS V0.3.16 Beta22
  3. User is impatient and kills PPS when it's in the middle of the initial setup (which can take 10's of minutes) - possibly leaving behind corrupted databases that need to be cleaned up before trying again.
See post #41 in this discussion for download locations for (1) and (2).
robert8450
Grand Rapids, Mi
Sorry.. but I read the entire 4 pages and my solution was not mentioned in this thread.
... AND what I posted above is EXACTLY my solution and what I did to fix the problem for me.
I posted what I did to fix the problem for anyone with the same problem. Anyone can read and do what I did, I posted it to help others without using the beta version.
robert8450
Grand Rapids, Mi
pro106import
Milford, Ct. perched high above Long Island Sound
Close PPS software ( hopefully you already updated it to the latest)
Under the C:\ProgramData\Unication file directory, rename the "RadioReference" folder to something else (like RadioReferencebad)
Open PPS Software
Click Import Radio Reference icon in upper right of PPS software
Be patient and wait for the DB to import completely. Depending on your internet or whatever the reason, it could take 10-20 minutes.
You can do this procedure instead of uninstalling the whole PPS. Just rename that folder and it will compile it new.
jackculb
Ohio
I wonder if it is a RR User ID character length issue ... even with version PPS V0.3.16 Beta22? It works with a RR User ID with 8 characters yet does not work with a user ID with 22 characters ... even when starting with a fresh "RadioReference" folder. Do those having issues still have a longer character RR ID?
