How Common Is The Radio Reference Import Error Issue?
Uni1
Unication Representative
DFW Texas
bob550
Albany County, NY
If you are getting the password error download new PPS which resolves the password issue. There are no other new user features to the new PPS.
Do you recommend those of us who have not had password errors also download and install this PPS update?
jeffhochberg
Atlanta, GA
I tried it with 03-16-21 and, aside from having to wait 10 to 15 minutes for it to initialize the first time, it worked for me with my RR credentials. Sorry to hear it's not working for some of you guys. At least the manual import feature works! That's a good option.
I see this Beta 22 version...is that supposed to resolve the RR connection issue?
CbusRog
Columbus, Ohio
I was having the import problem when 1.31 first came out. The first time I used it, it worked. Subsequent attempts to import resulted in PPS crashing. Login always worked. Event Viewer logs indicated that ASP.NET was throwing an error. Checking Windows Features showed the ASP.NET wasn't enabled. I installed the latest version and enabled it, but that still didn't help. I renamed the RadioReference folder, then let PPS recreate it, and all has been good so far. YMMV.
n1das
Nashua, NH
I've been having the same import RR problem as others have reported and I have 3.16.21 PPS. I will install the .NET Framework update that Uni1 mentioned. I am running Windows 10 on my Lenovo X1Carbon laptop. My laptop was upgraded to Windows 10 from Windows 7 Professional a while ago.
Where is the RadioReference folder located? I have been unable to find this folder on my PC to try the rename trick. It looks like the PPS installation didn't create this folder.
CbusRog
Columbus, Ohio
It's in a hidden folder. Open File Explorer. Click View, then put a check-mark in Hidden Items. Navigate to folder C:\ProgramData\Unication. The RadioReference folder will be there.
burner50
The Third Variable
NC Iowa
I don't think PPS builds that directory until you try to import the first time.
NJFireD1
NJ
If your PPS crashes when trying to import, Install the below Microsoft update.
still getting the wrong password or no internet connection issue after installing the Beta. But are good.
I have downloaded the new version for my G4 and it still says that my user name and password are wrong. Could this possibly be because I am a feed provider and my subscription status shows s never expired? Not sure why I cant log in.
This is the error im getting. My brother in law just logged in fine. He is not a feed provider. Anything I could try?
  • Like
Reactions: qc
