DSDPlus How do I get rid of 'CACH ERR'
Pr999
WRYF747
Plainwell, Michigan
I'm using Airspy SDR# and I think I have everything set up, but I have one problem; I just relized that I've been getting a 'CACH ERR' when decoding. How can I fix this. I have the free version of DSDPlus btw.
dave3825
Suffolk County NY
Errors are usually one of two things. PPM is off, or not a strong enough, or too much signal. What are you using for an antenna and how far are you from the signal your trying to decode?
dave3825
Suffolk County NY
I'm actually using a someones SDR stream from Airspy
Oh, so you don't own an airspy, your just using one on the Spy Server Network. Only thing you can really do is play with gain and make sure filter audio is unchecked. I tried that in the past on conventional p25 freqs.
dave3825
Suffolk County NY
Not sure what version your running but on 17xx it's in the Audio Tab. Make sure its not checked..
dave3825
Suffolk County NY
The highest I have is 1909. Should be the same. Click the 3 horizontal lines (upper left)
Then select Audio.
dave3825
Suffolk County NY
If its a conventional channel, it should decode. If its trunked, I am not sure if trunked audio can be decoded via Airspy Network. It should decode individual voice channels at any event. You also never stated what version of DSDplus you have. Public version will not do phase 2 audio.
