Howell County Question
tvengr
Well Known Member
Baltimore County, MD
Is there an alternate control channel frequency for the MOSWIN, West Plains 700, Howell County site? Thanks!
wbloss
Human
Joplin MO
Try 769.41875 - it's not been identified but "fits" the template
SWMORadios
Polk County, Mo
@wbloss is correct on the alternate control channel
chaebnels for West Plains are:
  1. 769.16875 (control 1/ primary)
  2. 769.41875 (control 2/ secondary control)
  3. 769.66875
  4. 769.91875
  5. 770.16875
  6. 770.41875
Info comes direct from a spreadsheet of all the MOSWIN frequencies from 2019 July.
tvengr
Well Known Member
One other question: Do the Eminence, Shannon County and Thayer, Oregon County sites both have the same site NAC code of 1C5? Just verifying that the database is correct. Thanks!
SWMORadios
Polk County, Mo
I’ve not been far enough east to pick those sites up. If you’re in those areas do a direct entry on the control channel and you should be able to find out.
wbloss
Human
Joplin MO
What scanner are you using?
tvengr
Well Known Member
This would be for the SDS100 and SDS200. I am aware that they are the only scanners that accept site NAC codes. Unfortunately, I am a little out of range in Baltimore Co MD to search for the NAC.
tvengr
Well Known Member
I can try to reach out to a couple sources I have down that way and see if they can look up the NAC for me.
I don't want to put you to all of that trouble. I am sure that someone in the immediate area will have that info. Thanks for your response!
SWMORadios
Polk County, Mo
No trouble at all. It’s just a simple text to the tech for that area. I frequent the south central Missouri area, but those two sites don’t cover the area that I go to.
SWMORadios
Polk County, Mo
Just checked with a tech. He said he doesn’t know the NAC. The state had updated NAC for several sites around the state this past spring & summer. So without doing a read of the radio he doesn’t know. So for this sites as long as you have the control channels you’ll be good to go. And just leave those sites as NAC Search.
wbloss
Human
Joplin MO
AND if you find a SIte NAC that is different from the Database, please submit!
lukestokes
I am in Howell County, Missouri and have been out of the hobby for a while. The frequencies that I used to listen to are mostly dead. I have found Broadcastify (affiliated with RR) to have a channel that is very active in my area. How can I learn the frequency for the content I am listening to on Broadcastify? It is labeled Howell County Public Safety / 37595. TIA
SWMORadios
Polk County, Mo
Howell county as far as Law e for event goes is entirely on MoSWIN. So there really isn’t a given frequency that they’re on like there would’ve been back in the old days. Missouri Statewide Wireless Interoperable Network (MOSWIN) Trunking System, Statewide, Multi-State
lukestokes
Thank you for the quick reply. I guess that's why I am not hearing much on my Baofeng handhelds. What is the next step to listen if I don't want to stream all the time? Do I need a trunking scanner with the 5 frequencies programmed into it?
