HP782 Wideband Unlocking
Pyro25
Try this first:
Open Notepad/Notepad++ or your fav text editor
Simply enter abcdef then save the file as cpssuperlicense.key (make sure it actually saves as .key, not .key.txt or similar)
Put this file in C:\
Launch CPS, read radio, go to Feature Control and see if you can now uncheck Only Narrow Band
I tried that ladt night but it did not work. I'll try again today after work. Thanks!
I gave it a try, I put it in C:\ and the folder above and it still wouldnt allow me to change the features or the bandwidth of the channel. I also tried putting it in the app file as suggested by a user. I want to reset to default but I need the correct default file for radio data version D8.05.06.004.
N4AR
Hampton, VA
I have tried it as well. I was able to change the Region on the CPS and bring the U2 radio down to 432-512 but I have not been able to get this to work. Currently on Firmware A9.02.04.001 and CPS. Not the end of the world if I cannot get it to work since I have a Dual Band D-star radio in the truck, but would be nice to have this able to run on Analog Repeaters.
N4AR
Hampton, VA
If anyone has an FCR file for the Newer CPS that has been generated they can share let me know. I think there is a way to hex edit it, Thanks
rmetcalf
Tennessee
Apparently
Try this first:
Apparently this no longer works on newer versions of software. I'm using the V2.6.08.11.NA2 for the HP series and it's not working.
rmetcalf
Tennessee
Apparently
I stand corrected on this not working.
I opened the code plug from my save file (after forgetting about it for months) went to feature control and I noticed the Only Narrow Band box was able to be unchecked. I connected my radio and "Wrote" to the radio and now... it works. I read the radio and "Only Narrow Band" is Unchecked
Hope this helps (y)
