HP-2: I\Deleteing
hub95
I forgot to remember how to delete some frequencies on my home patrol 2 scanner
hiegtx
Mentor
Dallas, TX
Unless you have the Extreme Upgrade, you'll have to make the deletion, and/or any other changes, in Sentinel, then write the updated Favorites list to your HP-2.
If you Do have the Extreme Upgrade:
Press Menu
Then Advanced Menu
Then Advanced Option
At the next screen, you can select Edit Favorites list, then pick the List, then System that needs the deletion.
Or
If you have the Extreme Upgrade, hold on the channel you want to delete.
Then tap the < on the right edge of the screen on the same line of the channel.
From the pop-up menu, press the Advanced option.
That gets you to a screen where you can edit the channel. One of the choices you have is to delete it.
hub95
Heres the deal my grandson found my scanner and messed it up so bad that I have no glue what he did it scans but I dont hear any thing ( i did
check the volume) I put inthe zip code still nothing The place I got is not around anymore im not a techie guy any ideas
Chuck
wtp
Port Charlotte FL
squelch setting ?
and you might have meant un-delete.
i am just making that up, don't ask about it.
hiegtx
Mentor
Dallas, TX
Chuck
If he 'just found' the HP-2, it's database may be well out of date.
On the scanner:
Press the Menu button (if it's currently scanning, that button will be in the lower left corner of the display).
On the Menu screen, press the Advanced Menu key.
On the Advanced Menu screen, press the Version Information key (you may need to first press the 'down arrow' at the bottom of the menu to get to the next page).
The Version Information screen will show you the current database version on the scanner. I suspect it will be well out of date. If so, and if you have the cable to connect the scanner to a PC, then you need to update it via the correct version of Sentinel.
First, though, check to see which Service Types are enabled. The four Public Safety categories are Law, Fire, EMS, & Multi. For each of those, there are three subcategories- Dispatch, Talk, and Tac. Make sure all are enabled. (Law Dispatch, Law Talk, Law Tac, Fire Dispatch, Fire Talk, .....etc)
If you don't have Sentinel installed, you can find the link to download it here:
You will also need the data cable.
Update the database in Sentinel. Then, connect the data cable to the scanner and the PC. At the prompt on the scanner's screen, select Mass Storage Mode. Once the scanner is connected in Mass Storage mode, write information to the scanner.
With the updated database, see if you can now get any reception using your location & range.
The Easier to Read manual that covers your scanner can also help walk you through what needs to be done. You can find it here:
hiegtx
Mentor
Dallas, TX
my data base was at 12/5/2021
If that is the database date in the scanner, then make sure that the correct service types are enabled, that the scanner saved your correct location, and that you have the desired range set.
What is your location? City (or county) & state?
hub95
I can get the ems/hosptial and the state patrol but not the local police/sheriff my zip is 56031 Matin County Minn Have the law,fire,ems, multi and disp talk and tac Im sure its a setting but i dont know what one
Chuck
hub95
Well it was on all night never made a sound and it should have the changes I made didt help maybe the service types are messed up well I got tp go move the 15in of snow we got the other day so if you have any ideas I check back at the today
Thanks Chuck
hub95
I had it to a guys house and he didnt hear a thing all day when i got it home I got the local pd dispatch so Im going to what else I get if any
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Are these what you are trying to hear? Is it a busy system out your way?
It sounds like you said your were able to get 34812.
Martin County Talkgroups
DEC HEX Mode Alpha TagDescriptionTag
3480087f0DMT ROAMMartin County Roaming Multi-Dispatch
3480387f3DMT 3Martin Co MT3 Multi-Tac
3481287fcDMT LAW DISPLaw Enforcement Dispatch Law Dispatch
3481487feDMAYO HOSPMCHS Fairmont - Mayo Clinic Health System - Fairmont hospital Hospital
348178801DMT ROADSMartin County Roads Public Works
hub95
Thats what I had before plus155-82000 Fairmont public works do I need all of theses law dispatch ,tac,talk ems dispatch tac, talk fire dispatch tac,talk multi dispatch tac and talk I still cant find how I got the 155-82000 and i want it if i can I think I figured it out was a setting i think sometimes its mostly mayo and cops
Chuck
hub95
DECHEXMode Alpha TagDescriptionTag
3480087f0DMT ROAMMartin County RoamingMulti-Dispatch
3480387f3DMT 3Martin Co MT3Multi-Tac
3481287fcDMT LAW DISPLaw Enforcement DispatchLaw Dispatch
3481487feDMAYO HOSPMCHS Fairmont - Mayo Clinic Health System - Fairmont hospitalHospital
348178801DMT ROADSMartin County RoadsPublic Works
hub95
I still think theres a setting or something not right because I can listen to it all day and nothing once or twice i will hear stuff but not like a week ago I have no clue what service types i should have can you help me with that
hub95
I think we got it fixed it was a setting I found a guy who had a hp2 at one time took him 5mn to fix it now if I can only add 155-82000
Thank You for all the help Chuck
