from basic brochure I have noticed a country selection, I assume is a different Band Plan as TRX-1It should be much the same as the IC-R30 i.e. a generic bandplan and you set the appropriate steps yourself.
Were they both set to NFM? I see the 436 is. Not sure how much of a difference it would make but NWR should be FM, not NFM.Hey @krtz07 !
Ok, here is a comparison of the two radios on the same table using the same antenna (Icom FA-S270C). I did elevate the Icom on a couple books so the antenna base was at the same height as the Uniden.
I tried to match the volume of the two radios beforehand by opening the squelch on a frequency one MhZ up and adjusting until the sounded kind of the same.
This isn’t scientific or anything, just a hastily thrown together comparison.
They both were on NFM.Were they both set to NFM? I see the 436 is. Not sure how much of a difference it would make but NWR should be FM, not NFM.
North American railroads are slowly moving towards NXDN on their current VHF channels, but it's a very, very slow process.When Icom first announced the IC-R15, they said it was geared for air band & railroad enthusiasts as can be seen from the pics, and since these bands are analog, no need for digital modes.
Actually, I have a request: could someone send me a copy of the memory channel file installed in the radio? I forgot to capture it and nuked it when I installed mine, and neither of the manuals shows the format of the .csv files for this model. Thank you.I received my R15 on Friday (from Moonraker in the UK). It's a neat radio, with an interface and functionality much like the ID-52, but a bit smaller and considerably lighter. Side-by-side comparison leads me to say that it's almost as sensitive a receiver as the ID-52, and certainly more sensitive than the R30. The stock antenna is excellent for VHF Air, less so for UHF. But when I try it with a SignalStick it overloads with noise. I can't get the VSC function (the voice-only squelch, that's supposed to filter out nonvoice channels) to work, not sure why. And I'm not yet certain about this, but I'm finding my Smiley antennas are not as well matched to the R15 as they are to the ID-52. But if you scan analog channels, this is a great little machine. It scans extremely fast, has good audio, and a pretty easy-to-learn menu-driven interface. Even though it doesn't transmit, I loaded in the CSV spreadsheet of my channel memories from the ID-52 and the R-15 started scanning them with no problem. In general, I'm pleased.
This is a little concerning. Was the overload on VHF or UHF, or both?The stock antenna is excellent for VHF Air, less so for UHF. But when I try it with a SignalStick it overloads with noise.
Haven't yet done milair. I'm in San Francisco so monitoring milair without an antenna and filters is difficult. But will try."Side-by-side comparison leads me to say that it's almost as sensitive a receiver as the ID-52, and certainly more sensitive than the R30."
Have you carried out a direct comparison between the IC-R15 and the IC-R30 in the UHF military aviation region?
I'll keep trying with the Sticks. In general they work really well for me, and I might have been hearing transient noise.This is a little concerning. Was the overload on VHF or UHF, or both?
I use my Signal Sticks for both VHF and UHF airband and they do well on my R2/R6/R30.
You mentioned is potentially more sensitive than the R30?I'll keep trying with the Sticks. In general they work really well for me, and I might have been hearing transient noise.
I'll do a NOAA weather test.
As for the R30, I love the radio as everyone else seems to, but i have never found it as sensitive a receiver as the ID-52, even with exactly the same antenna setup.
If possible could you compare the weakest weather radio frequency between R15 and R30?
I do remember the R30 let some more noise in but nothing which wasn't a deal breaker and it still has excellent selectivity and sensitivity compared to my ICOM V86. Even though I think the V86 suppressed noise a bit better!
