Indoor Antenna Idea
MrHellion
Central California
So I recently had surgery and have to spend some time in a "skilled nursing facility" a.k.a. Nursing Home, I am going to be here for quite a while and wanted to play radio during my stay. HF is out of the question from all the medical devices, o2 generator, TVs, etc. So I had the wife bring me my BC125 handheld. The Nagoya anteena works fine but still wasn't happy. So I did this. What do you all think?
KB4MSZ
Billy
Tampa, Florida
It's a good start. If you can run the coax horizontal to the opposite corner of the vent and then let it drop down, it would likely perform a bit better. That would keep the coax from running alongside the antenna so close.
K4EET
Chaplain
Severn, Maryland, USA
Sorry to hear that you’ll be in a skilled nursing facility for a period of time. Praying that you have a speedy recovery ❤️‍🩹.
I have done what you have done at my office. Billy, @KB4MSZ, does have a good suggestion about trying to keep the coax from hanging next to the antenna. That may be difficult to do without the help of the facility maintenance department.
One other suggestion. Since the antenna is upside-down, be sure to hold the microphone upside-down as well. That way, your signal will radiate from the antenna right side-up so people you are talking to will not need to stand on their heads. - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Just kidding… 😂😂😂
73, Dave K4EET
MiCon
Mike
central AZ
Appreciate you sharing this idea, and any others you come up with. Good choice for an office location, or at home where you don't want to (or can't: rental, apartment, etc) poke holes in the wall, or you just need a temporary set-up.
Enjoy the down-time, and God-speed on your recovery.
MrHellion
Central California
After reading the responses I was remiss to mention this is/was RX only. VHF/UHF/SHF is dead here though we have repeaters, not systems, but stand alone repeaters that cover from near Sacramento al the way south to Bakersfield and all points inbetween. My "ghetto fabulous" upside down antenna idea was for my scanner. I figured vertical is vertical. *shrug* So after reading the posts i asked the tallest dude that works here to do this "mod" for me. Comments?
First off, I hope your recovery goes smooth.
Second, I needed a temporary antenna in my office and I did the exact same thing. Mag mount to the T-bar ceiling frame, thumb tack to route the coax away from the radio.
Uh, yeah, you really do not want to attach anything to the fire sprinkler. Eventually someone is going to see that and get a might cranky about it. I'd recommend finding the tall guy and having him remove that. Have someone on the "outside" get you a 3M Command Strip hook to do the cable routing.
MiCon
Mike
central AZ
First and foremost, DEFINITELY do not attach it (or anything else) to the sprinkler head in any way. Reroute that cable immediately.
Second, anyone who actually read your post would realize that you said you were using a BC-125.
Third, I'm no antenna expert, and there are people on this forum who will feel the need to explain antenna polarity, length, gain, location & position, etc, ad nauseum. They don't take into consideration this is a temporary 'at best' situation. As a guest at this facility, you have next to no control over what you can do here. This is one of those "Do the best that you can with what you have", and "Use whatever works" type of situations. If this works, use it.
hill
Middle River, MD
It will fine upside down.
I live in an apartment with suspended ceilings and have several .mobile mag mounts stuck on the ceiling tracks the same way.
KCA6YU
King Charles Adam 6 Young Union
Las Vegas NV
Hope you get better. And thats a damn fine idea and one I never thought of.
MrHellion
Central California
Took your advice and just have it hanging, I was curious as to just RX why the coax would matter, If were TX I would understand, TBH I am on enough painkillers to drop an elephant, that is why I asked the question in the first place as I admit I may not be thinking as clearly as I should. Thank you for the advice,
Advice taken! Thank you!
73, Dave K4EET
Good joke! Scanner is now upside down! =P
Great idea to get the coax away from the antenna. The facility actually has these on hand and on Monday I'll have the maintenance guy get me a plastic hook to run it away from the antenna.
KB4MSZ
Billy
Tampa, Florida
I was gonna say that....
The shield on the coax acts as a reflector. It'll change the impedance of the antenna (not a big deal for a scanner) and depending on how close, it can detune the antenna and make it slightly directional. Same reason you'll see vertical antennas that are mounted on the side of a tower stood off by some amount of spacing.
