Well, the initial tests are complete, and they are VERY positive. First off, the RYN25DI is the new champ for low power consumption--25mA average, which is even more impressive considering that it outputs RS-232 directly, and does NOT need the MAX3232 converter module, which draws an additional 8-10mA. The previous champ in that department, the Ladybird + MAX3232, draws 35-40mA in comparison.
RFI is also virtually non-existent--better than any other module except the Reyax RY636AI--just a hint of noise in the 220-260MHz region with no ferrites or capacitors connected. Putting a ferrite on the power leads next to the module and jumpering the power pads with a 0.1μF capacitor seems to kill it completely.
Reception is quite good. Satellite lock is intermittent in my basement safe cubbyhole, but solid everywhere else. Like the other Reyax modules, fit and finish is excellent.
I'm sufficiently impressed with the RYN25DI that I pulled the GMouse out of my 436 and replaced it with the RYN25DI. The GMouse wasn't bad; it didn't seem to affect sensitivity when doing side-by-side comparisons, but it did cause some background hum on some frequencies when it was running. Testing with the RYN25DI so far indicates no background noise whatsoever on any frequency when it is running.
