WTF, this is new out of the bag.
I finally received the ATGM336H today.
BDS GPS Dual-mode Module Flight Control Satellite ATGM336H Replacement NEO-M8N S
I installed it by driving the TTL side of the RS232 UART directly from the GPS module since both are 3.3 v compliant but I'm not seeing any GPS activity recoginzed by the HomePatrol.
Any luck getting the fault traced?
I can't imagine why applying 3.3 to a 3.3 line would toast it but it's sounding like that's the issue.
Makes sense. I'll dig into it again and might hit you up about it if I keep having issues. ThanksThe problem arises when one output is sending 3.3V, and the other is sending 0V. If these outputs are connected together, you have a 3.3V power supply that is being shorted out. Unless both outputs have short circuit protection, something is going to fry.
Put an oscilloscope on the scanner UART output pin, and see if it is showing data (rapidly fluctuating between 0V and 3.3V), or if it is stuck at 0V or 3.3V. Use 20-50ms/division for your x unit, with a trigger threshold of 1-2V and triggering when input drops below the threshold. A normal multimeter won't react fast enough to give you a good reading if serial data is active.
If your scope supports multiple inputs, connect the second input to the scanner UART STATUS pin to see if it is indicating valid data going to the scanner when the scanner UART is getting good RS-232 input.
You want me to take a look at it?
