Is a external antenna really necessary?
lcat06
I’m getting a sds100 and I am wondering if I need a external antenna on my vehicle. I have good recommendations for external antennas but I don’t really know if it is completely necessary to have one in the first place. I live in Jefferson County, AL and the stock antenna on the sds100 works well enough in my home county but, for when I’m travelling should I get an external antenna or not? What are some very low profile antennas that would do this (I like the shotgun shell design) and cheap stico recommendations would be good too.
dave3825
Suffolk County NY
That one was regarding ham antenna this is just for scanning
Really? Could have sworn your other thread said this.
I am getting a SDS100 for use in and out of my vehicle. I need a recommendation for the rubber duck antenna. I am monitoring the AIRS p25 phase 2 simulcast system in the Birmingham area. Ideally the rubber duck antenna will be as low profile as possible without suffering a major performance loss. I also need an antenna for the sds100 to use in my car that I will attach to an NMO mount on my vehicles roof. I would like this to be as low-profile and look tactical as possible. I like the stubby antennas on police vehicles and like this design but I do not know if this will sacrifice long range scanning performance. I am also trying to monitor air band and federal frequencies. They both need to be very durable and high performing without looking obnoxiously large and intrusive. Thanks for the help!
kc2asb
NYC Area
Based on what you wrote in your original post quoted above, you want long range receive. A handheld inside your vehicle using the stock antenna is not going to deliver that performance. So, yes, it appears you should get an external antenna
Read through this thread - plenty of good recommendations for mobile antennas
Your vehicle will act like a Faraday cage and block RF pretty well. All that metal and tinted glass do a pretty good job.
If the traffic you want to listen to is very close by, there may be enough RF leaking in through the windows for the scanner to hear the traffic.
But if you get on the fringes of coverage, it's going to suffer.
If you want the most range from your scanner, getting the antenna outside the vehicle will make a big difference. That's why police cars, fire trucks, ambulances, and public works vehicles will usually have a mobile radio with an antenna on the roof.
No one can tell you what is going to work for your exact situation. You have to decide if the function of your scanner sitting inside the car with no external antenna is 'good enough' for you, or if you need more.
After 30+ years, I -always- install an external antenna on my vehicles for my mobile radios. I won't do anything less.
W9WSS
Retired LEO
Westmont, DuPage County, IL USA
Don't use a "transit-style" antenna for a scanner unless you're only listening for a frequency that antenna is tuned for. They don't even work that well for two-way communication I would say just less than a 1/4 wave cut for a specific band
Larsen, Em-Wave, and Laird make excellent mobile scanner antennas. All of which are available at the Antenna Farm (or Amazon).
I have all Em-Wave antennas on my SUV for Ham Radio and scanning.
What mmckenna says is 100% on the mark. He's a career communications professional and has great advice to share on these forums.
MUTNAV
Not to be a funny guy, BUT... Asking if you should use an external antenna on Radio-Reference will almost always get you an answer of "of course you should have a bigger more capable antenna".
If you want an answer that is different than a bigger antenna is better, that's where the spouse comes in.:(
What I need is an article or thread on how to convince a spouse that an external antenna is a good idea. (There was an article in a kit plane building magazine about different techniques to use to convince a spouse that a kit plane is a good idea) :)
I helped my wife get her Technician ticket and I put a VHF mobile in her truck. She doesn't mind the antenna. But I made damn sure it was a basic 1/4 wave, not one of those butt ugly, goofy a$$'d looking hamtacular monstrosities.
Some of those antennas remind me of BCG's.
dave3825
Suffolk County NY
Start with the basics. An antenna up high outside will receive than one better inside 4 walls that could contain foil backed insulation or any other housing material that blocks or reduces rf.
Also know that any antenna that resides outside and has a feed line going into your home needs to be grounded.
Bob1955
Eastchester, NY
When your Bearcat SDS100 is in a vehicle, you are surrounded by metal so you will lose a lot of the signals.
What frequency(frequencies) do you want to monitor and what type of vehicle do you own? This will help me out plus the group too.
Have a good week and stay cool.
Bob
merlin
DN32su
Mandatory, No, but it sure helps a lot with external antennas.
For base setup, higher is better and larger base type are better.
Air band, you really need a 1/4 wave ground plane for best performance.
lcat06
What if I wa only scanning 800mhz trunked. Would a Motorola can style antenna have better performance than a larsen triband
UTE-GE
I run one of these on my SDS100 that rides in my car and take into work, a metal building. It can hear fine on 700/800 the next county over. Car or building.
But, as they say YMMV. And yes, that's ONLY for 700/800 otherwise It's DEEF.
dave3825
Suffolk County NY
Usually an antenna tuned for area of interest should perform the best. A tri band is tuned for three bands. Is what your calling a Motorola can antenna tuned for the range of 800 your looking for?
I use a simple nmo mount with a 18 or 19 inch whip and it’s perfect for my needs. Also run a nmo tuned for 800 and receive 7/800, 450/470 and 118/160 without issue.
Just buy and try. That’s what scamazon free returns is for. They even offer “don’t need it any more” as one of the choices when doing a return.
Motorola doesn't make antennas, they resell someone else's with a substantial markup.
As Dave said, band specific antennas usually work best, so if all you need is 800MHz, then a single band 800MHz antenna might be your best option.
Remember that most of these systems are designed for on-street portable radio use, so anything better than that will give you good results in the intended coverage area. If you are outside the intended coverage area, then you might want something with a bit more gain.
Best bang for you buck on the 800MHz Mobile antenna side is:
I just installed a bunch of those on transit buses.
If you want something with some more gain:
-or-
lcat06
It will work for 800MHz. But if you don't already own it, I'd still recommend the basic 1/4 wave antenna linked to above.
Okay tell me this… compare the performance of a Motorola haf4013 near the sharkfin in the Toyota 4Runner compared to that 1/4 wave in the dead center, and then compare that to the stock antenna. I see police vehicles with these Pctel and Motorola can antennas in my city
