Bob here, maker of ProScan chiming in. Thanks for trying out ProScan. Let us know of any snags. On the Web Server setup, see the document on my
ProScan website. It's located in the lower right corner. Ignore the part about the BCD536HP if you don't have that model, and just go to the Web Server part.
There's a few things here that are not correct. I just want to clear it up so you will get a better understanding of how ProScan, Sentinel, and the scanner works.
1. On the Mass Storage / Serial Port prompt = ProScan has no control over that. A USB cable detected will bring up the prompt otherwise it will go into Serial Port mode. It's called 'Serial Port' mode which is the same as when the scanner is in normal operation (including the menus) or in other words, anytime the scanner is not in Mass Storage mode. If you have a SDS200 then there's another mode, FTP mode.
2. On the Sentinel showing in the com port - Sentinel doesn't use the comm port, It doesn't log or show a display. It just uses the Mass Storage mode for reading and writing the database, favorites, profile, and firmware.
3. Yes, when using ProScan, you have to switch from Serial Port to Mass Storage mode if you're using ProScan for logging or the display.
4. Sentinel doesn't directly import from the RRDB(Radio Reference Database). ProScan importing from the RRDB may seem to be clunky but maybe over time, your option may change or it could be due to the many options.
