Alright this has been a problem for awhile i have tried programming every way you can i have used OFT and conventional but i get the same results.
HERE is the system and on dsdplus there is a data signal on all the channels it will go away at times but stays constant but when the my 536HP or SDS100 comes to that system it basically slows waaaaayy down and cycles through each channel really slowly , I know that it has to check the signal and see if there is any activity on it but i have tried to read as much as i can from other posts and some of it i don't understand as much but is there any way to tweak anything or a way to set it up so it isn't so slow?
Also i have a P25 phase 1 conv channel that has a really strong signal and i can set dsdpllus to it and it will decode clear and strong but both my scanners pass it up i tried using P25 OFT and conventional and my scanners won't even see it but dsdplus is decoding it fine with 0 issues i tried setting a hold time and delay times but this really has me suspicious of my own scanners because if they are passing up frequencies that clearly have a strong signal with traffic then who's to say it isn't passing up ton's more active frequencies i have set in my FL?.
Just very confusing stuff and if anyone has any advice i would really appreciate it . Thanks.
