Is there a way to...
jonwienke
More Info Coming Soon!
VA
Why? In general you should filter traffic by talkgroup, not frequency or timeslot.
marksmith
Anne Arundel County, MD
The 536 automaticly skips the encrypted transmissions.
/Ubbe
Interesting to hear it apparently does this in DMR systems. It DOES NOT skip encrypted transmissions from a Phase 2 P25 system.
536/436/WS1095/HP1/HP2/996T/996XT/996P2/396XT/325P2/PSR800/15X/others
werinshades
Chicago , IL
Lockout one slot of a dmr channel or only hear the audio that passes on a either slot?
Make sure you program it as DMR One Frequency and not in conventional mode. Program in the talkgroup via Sentinel and under TDMA Slot select the one you want to listen to. Run it in ID Scan Mode and you should be set.
BigC801
Kansas City
Why would you want to? So you can lock out slot 1 and scan a system as conventional channels.
The X36hp scanners do a poor job of scanning TIII systems so that is why i would like the option...
And you can lock out or scan just one slot on the TRX 1 & 2 Scanners. IF we could just melt the 436hp and TRX 1 together then we might have the perfect scanner.
jonwienke
VA
The bugs currently affecting DMR trunked system reception also affect One Frequency systems, so you gain NOTHING by doing this. Uniden is working on the issues and will likely have a fix out next week. Have a bit of patience and program the system for what it is.
