Issues programming CDM750 using Chirp and CPS
jbesedic
Belleair, Florida
I have two CDM750 that I want to program. I can get into Chirp with no issues and put the radio in the ham band using Waris module.
The issue is the CPS version R06.12.02 or R06.12.09 will not read the radio. I've tried loading the sample file and writing to it but for some reason I cannot write the file.
To better explain it I created a video and posted it to youtube.com
If someone knows what I am doing wrong please reply. I've done with exact method for my CDM1550ls with no issues at all.
Here is a youtube video showing the issues
https://youtu.be/7PyIr0ibwBA
clbsquared
Isle of Wight County
Why are you using CHIRP? I’ve never known a Motorola radio to be the least bit compatible with CHIRP. A simple hex edit within the Professional CPS is all you need to go out of band. With that said, your eeprom probably needs to be replaced. The professional series radios have a limited number of times they can be programmed.
clbsquared
Actually, it sounds like you do have issues. But, that radio isn't supported by Chirp, so it's not surprising. I'd try using the OEM software.
I think it’s too late for OEM software. Looks like somehow CHIRP was able to jam in a lot of features that aren’t compatible with the CDM 750 radios. Trunking being one of them.
jbesedic
Belleair, Florida
Does anyone have a code plug for this CDM750 AAM25SKC9PW1AN radio? I know that there are samples in the folder but that is failing as well. I just want to see if a good working code plug that someone in this forum has would work
a417
you didn't save a known good one before you violated it with CHIRP?
If the samples aren't working, I'd be wondering if a firmware flash might save you...
